Calculation Type in Elastic Report
Forum Home › Forums › Understanding the Software › Calculation Type in Elastic Report
  • #10673
    Hari
    The possible calculation types of data items:
    * Val – the value of the bound input channel at the current time point,
    * FirstVal – the value at the first time point of the working period,
    * LastVal – the value at the last time point of the working period,
    * Diff – the difference between the values at the current and previous time points,
    * DiffNext – the difference between the values at the next and current time points,
    * Const – the constant value to insert in an appropriate cell,
    * Formula – the formula to insert in an appropriate cell. Supported for Excel output format only,
    * Now – the report building time.
    Similarly, Any other Calculation Type is available to calculate average of that time?
    #10674
    In Elastic Report, to calculate average by column or row, use calcAvg attribute. See ElasticRepExample.xml
    #10706
    Hari
    I want to calculate average of particular time, for eg. Average value of 3.00AM – 4.00AM
    We are using CalcAvg formula to calculate average value of entire column, but I need to calculate average value of particular hour.
    #10714
    If you mean that you need an average of all datapoints between 3 and 4am, you should use averaging formulas in the configuration database.
    #10715
    Hari
    Can you explain where i need to add that average formula in configuration database?
    #10736
    You should add the formulas into the Formulas table. Then upload configuration to check if it still works. If OK, set formulas to input channels as written here.
    #10782
    Hari
    Thanks Mikhail
    #10816
    Hari
    Hi Mikhail,
    If i add those formulas in the formula table and upload that configuration, in browser it is showing as Server is Unavailable.
    #10825
    Check server log for errors.
