Forum Home › Forums › Understanding the Software › Sending Command Skipped
- This topic has 11 replies, 3 voices, and was last updated 4 years ago by
kcks66.
February 8, 2022 at 1:13 pm #10054
kcks66
ParticipantHi Mikhail,
I am configuring auto control module as below:
I got message “sending command skipped” which I don’t understand what cause this:
However, the input channel is always 0, as below:
Pls advice and thank you.
February 9, 2022 at 6:39 am #10055
manjey73ParticipantAs far as I remember, if you have a trigger at 0 and when you restart the server you have 0 there, then the command will be skipped. You need to do 1 in the channel, and then 0, that is, changes must occur. This is done in order not to send commands when restarting the server.
February 9, 2022 at 1:07 pm #10061
@manjey73 is right. To send a command, trigger requires a channel value change from 1 to 0, for example.February 11, 2022 at 2:43 am #10063kcks66
ParticipantHi manjey73 & Mikhail,
Thanks for the explanation. I am able to trigger now.
However, is there possibility to detect the ‘ — ‘ when the device is offline? Then send out email alert to inform recipient for such faulty.
February 11, 2022 at 6:30 am #10064
manjey73ParticipantI may be wrong, but in this case, the trigger should be set to the channel status and apply formulas that change the status.
February 11, 2022 at 12:09 pm #10065
MikhailModeratorI agree with the above.
February 11, 2022 at 12:32 pm #10066kcks66
I set to the channel status but I have no idea what to do next for the formula.
February 11, 2022 at 1:22 pm #10067
MikhailModeratorJust type 0
February 12, 2022 at 11:45 am #10068kcks66
It worked. Thank you.
September 16, 2022 at 1:39 pm #10785kcks66
I want to send out email alert when the device offline resume from ‘—‘ back to online with ‘number’.
I tried to set channel status to 1, but it doesn’t work.
Pls advice and thank you.September 16, 2022 at 3:18 pm #10787
Add a new channel of the calculated type that shows the device status.
Use the formula for the new channel:Stat(101) > 0 ? 1 : 0where 101 is the source channel number.September 23, 2022 at 6:48 am #10892kcks66
It is worked. Thank you.
