Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › How to Install Automatic Control Module in Raspberry PI
- This topic has 7 replies, 2 voices, and was last updated 4 years ago by
September 18, 2022 at 8:55 am #10798
CCKOH
ParticipantHi Manjey / Mikhail,
Can you guide me how to install Automatic Control Module for Raspberry PI?
I’m have copy the ScadaServer folder (from the downloaded Automatic Control Module) to /opt/scada/ScadaServer and obtain the trial key and upload the configuration.
However, when I’m start my Rapid Scada application, the Automatic Control Module do not start and operation.
September 18, 2022 at 9:26 am #10808
You should copy the files to the Linux machine and to the Windows machine. Activate the module in the project. You will find the computer code in the module log on Linux.
September 19, 2022 at 4:51 pm #10839CCKOH
ParticipantHi Mikhail,
I’m have copy the files \mod_auto_control_5.2.5.3_en\SCADA to both Windows and Linux machine.
I’m have activate the module in Windows Machine and the module is function perfectly.
I’m have Upload the Configuration to Linux Machine by using New Deployment profile for Linux Machine. However, the Auto Control Modules do not start and i’m do not find any computer code under dir scada/ScadaServer/Log.
Please guides me how to Activate the Auto Control Module for Linux Machine by using Administrator?
September 20, 2022 at 12:15 pm #10841
Does the file /opt/scada/ScadaServer/Log/ModAutoControl.log exist?
Are there any errors in ScadaServerSvc.log on the service start?September 21, 2022 at 12:37 am #10847CCKOH
ModAutoControl.log does not exist.
ScadaServerSvc.log do not show any error.
Im try to copy my whole project folder to Linux machine and run Administrator using Linux machine to obtain the computer code, but unsuccessful. Under the Auto Control Modules – Registration, the computer code area is empty and with a msg “to restart Scada Svc to obtain computer code”. Im try to restart Server using Administrator – Instances, but it show error msg “Invalid Username and Password”
Im have run out of idea ?September 21, 2022 at 7:26 am #10853
It looks like the module is not in use.
Check that /opt/scada/ScadaServer/Config/ScadaServerConfig.xml contains
<Module code="ModAutoControl" />September 22, 2022 at 1:18 am #10873CCKOH
Thank for your guidance.
After check the ScadaServerConfig.xml, the script do not contains “ModAutoControl”
Im realise during uploading of configuration, im have unchecked the Server option.
Once im Check back the option and uploading again, everything working fine now 🙂September 22, 2022 at 10:27 am #10886
MikhailModerator🙂
