Forum Home › Forums › Understanding the Software › Notification
- This topic has 13 replies, 2 voices, and was last updated 4 years ago by
September 18, 2022 at 5:35 am #10797
victorlamParticipantI have already installed Notification plug in. May I know how to set the condition that register 30001 will be alert with audible sound if the value =1 ? I have already ticked the checkbox event sound with tick on input channel 101?
Or I need to set more definition to apply this condition?
Thanks for your further advice and help on this notification command.
September 18, 2022 at 9:21 am #10805
MikhailModeratorAn event is displayed by Notification plugin if it has channel status, specified in PlgNotification.xml.
Try the formula for your input channel:
Cnl; Cnl > 0 ? 15 : CnlStatSeptember 18, 2022 at 10:03 am #10809
victorlamParticipantThanks for your support. May I know if I need to set the channel number here?
Cn1;Cn1 >0?15: CnlStat did not mention any channel number here.September 18, 2022 at 10:11 am #10810
victorlamParticipantOr do you need to install another plug in Automatic control, so that I can trigger the alarm when register 30001 =1. Or no need. Just add a line in plgnotification.xml and then solve the issue on my case.
September 18, 2022 at 10:25 am #10811
victorlamParticipantOr do I need to install another plug in Automatic control, so that I can trigger the alarm when register 30001 =1. Or no need. Just add a line in plgnotification.xml and then solve the issue on my case.
September 18, 2022 at 11:48 am #10813
victorlamParticipantMay I know “15” refers to what item being stated here?
September 19, 2022 at 7:11 am #10824
MikhailModeratorThe formula
Cnl; Cnl > 0 ? 15 : CnlStatdoes not contain particular channel number. It’s applied to the channel of the formula.15 is a channel status. You can see channel status IDs in the Event types table.
September 21, 2022 at 3:43 am #10848
victorlamParticipantHello, I have successfully used the notification plug in and browser have the alert sound when the register 30001 changed from 0 to 1 or 1 to 0 or other values which has been changed with the values. The alert sound only alerts for 1 second or 1.5 second just with short duration and then stop.
How can I have the alert sound keep alive until the register value was back to original state eg from 1 to 0? 1 is my alarm state (or not normal) and 0 is the normal state.
Can I implement this scenario?Thanks for your help on this.
September 21, 2022 at 7:21 am #10851
Could you make a screenshot of a notification panel of the plugin that contains an event?September 21, 2022 at 8:21 am #10856
victorlamParticipantHello Mikhail,
Please find the shared screenshot for your review reference and support:-
https://drive.google.com/file/d/1fn0kbncf7Se2M4usgGBeUFwU0_6SqVij/view?usp=sharing
https://drive.google.com/file/d/1KUcSuSRbmjOejlRmSZJWCYs9eN62t_ys/view?usp=sharing
I believe I am a new user that might have incorrect event or inproper setting behind.
FYI, my request is very simple. I would like to make a request that when a register value eg 30001 or 40001 that this value become one (1), then the alarm will be triggered and Webstation will be heard of alarm via notification plugin. Once the register value 30001 or 40001 or others changed to zero, the alarm will be off and there is no alarm triggered for alert or no sound (or as normal state).I might have something not correct. Please advise your help accordingly.
September 21, 2022 at 8:52 am #10857
MikhailModeratorThe above screenshots do not contain a panel of Notification panel plugin. It is shown automatically when a new event matches the plugin settings.
You can see this panel when click the Bell button.September 21, 2022 at 10:30 am #10861
victorlamParticipantHello, may be new on this platform. Can you advisee how is my panel of notification panel? I already installed with trial test key. And there is a bell nearby.
What is the problem that cannot have the alarm all the time for such register?September 21, 2022 at 10:32 am #10862
victorlamParticipantI have noticed that there is a bell icon next to admin at Webstation page.
May I know if I did not install the notification plugin properly? Or I need to install this plug in again. Please advise the further action on this.September 22, 2022 at 10:25 am #10884
MikhailModeratorAt least a screenshot should contain an event.
