victorlamParticipantOr do I need to install another plug in Automatic control, so that I can trigger the alarm when register 30001 =1. Or no need. Just add a line in plgnotification.xml and then solve the issue on my case.
victorlamParticipantOr do you need to install another plug in Automatic control, so that I can trigger the alarm when register 30001 =1. Or no need. Just add a line in plgnotification.xml and then solve the issue on my case.
victorlamParticipantThanks for your support. May I know if I need to set the channel number here?
Cn1;Cn1 >0?15: CnlStat did not mention any channel number here.
victorlamParticipantI am okay for using ChartPro plugin but I would like to clarify if we can select the data to be exported. For example, I would like to export the time log data of register 30001 with data bit 0 = 1 from Sept 1 to Sept 3 2022 record.
victorlamParticipantThanks! I have found the file and changed already for the testing.
victorlamParticipanthttps://drive.google.com/file/d/1p8qad3ieo17hD5MLc6P3UASsE40f4m5K/view?usp=sharing
May I know if I can change this text ” Rapid SCADA” as shown here?
victorlamParticipantThanks for the support. I try to write the program step by step and works now.
victorlamParticipantWhere can I check the communication line log status?
victorlamParticipantThanks for the reply. I try again and test if this works or not. Otherwise, I will report again.
victorlamParticipantHow about the contents inside the bracket, eg (101)?
victorlamParticipantSo you mean the formula is “DateTime.Now.To0ADate()”. I do not see this formula at the user manual.
victorlamParticipantBy the way, can I execute different commands or output channels at the same time here?
victorlamParticipantMay I have any comments for the toggle problem encountered?
victorlamParticipantFor scheme editor, I try to use LED but again the function is not working well.
1/ I see there is status color for every color selection. What is meaning for this based on the status color?2/ I set input channel number as 104 and action is Draw diagram. Not sure if this is correct to get LED to be displayed with the correct status on the screen.
Or I use the incorrect action for LED components? What should be the correct action for components LED?
For the action lists, Draw Diagram, Send Command, Send Command NOW? Do we have any restriction on this for those components like static text, dynamic text, static picture, dynamic picture?
Or what will be result for different combination used here? For example, LED – SEND COMMAND, it will be execute my command from input channel after certain time delay.
victorlamParticipantFor scheme editor, I try to test Toggle but this function is not working after trial.
We need to enter the value for input and output channel. May I know the criteria to get the mechanism that the status can be toggled really for my trial.
Behavior = Send Command NOW
Input channel 104
Output channel 101But it does not toggle here.
