String read and write operations
Forum Home Forums Understanding the Software Formulas String read and write operations
  • #17486
    詹森
    Hello, could you please take a look? Thank you very much
    Everything is a channel, and all values can be read and written through the channel. Now, when encountering the string type, reading and writing through commands cannot be achieved. How can this be realized?
    For example: Val(1) can obtain the value of channel 1, but what if channel 1 is an ASCII string? How can a string be obtained from a channel?
    There is also a write channel. If it is not a string, SetData() can be used for writing. But how can it be implemented if it is a string?
    Thank you very much for your help. Wish you a happy life!
    #17487
    詹森
    I see. It was my fault for not handling it well. There is a formula. Thank you. The problem has been solved
    #17498
