Blinking in faceplate not working
Forum Home › Forums › Runtime Bugs › Webstation Bugs › Blinking in faceplate not working
Viewing 10 posts - 1 through 10 (of 10 total)
  • #17516
    Fou
    I have try to trigger a blinking picture or text with channel 104 for test in a faceplate.
    It has never start to blink, but I’m able to do it with the visibility ( appears & disappears the same picture)”
    Even, blinking all the time not working in a fp.
    #17517
    Could you describe steps to reproduce the issue?
    #17519
    Fou
    Place a blinking object in a FP and add that FP in a mimic.
    The object is not blinking.
    (Lastest version of rapidscada)
    #17523
    I will check it and write here about the result. It will take some time.
    #17527
    Fou
    Also, in FP, the text alignement center don’t work.
    ( my mim and 2 fp)
    https://www.dropbox.com/scl/fi/zny6emls6n0l8u37jwbhb/Object.zip?rlkey=nug6lrrz4nq7357jpr0t8l2n9&st=sujjnm24&dl=0
    #17534
    Thanks for the information. I’ll be able to start testing and fixing it a little later.
    #17595
    To center text horizontally, set a fixed text width.
    #17596
    This is because the object in the example is not visible. I will check why.
    #17597
    In the mimic provided, I edited the instance of AI_Nameplate, bound the Alm property to the channel 104. I use the Hello World project. An image blinking properly when the channel 104 is On.
    #17600
    Fou
    oki i will check
