March 7, 2023 at 1:30 pm in reply to: Export channel data to excel for longer periode of time #12190
Jure
ParticipantIn PlgChartPro_Reg.xml is only RegKey and in ScadaWebConfig.xml I used search and there is no paramter that Would start with Max.
I have verison of scada 6.0.0.1 and PlgChartPro is 6.0.0.1.-
This reply was modified 3 years, 8 months ago by
Jure.
March 7, 2023 at 9:30 am in reply to: Export channel data to excel for longer periode of time #12186Jure
ParticipantI have installed V6, where can I configure that I CharPro will draw graphs for more then 31 days or to export data for more then 31 days?
Jure
ParticipantI run repair trough AspNetCoreModuleV2 installation and now it works OK. Thank you for the help.
Jure
ParticipantAlso If I go in to ScadaWeb folder and manually run ScadaWeb.exe it creates http server on port 5000. If I then try to open localhost:5000 it opens the login page.
Jure
ParticipantIf I try 10008 I get following error:
https://imgur.com/a/gMwyDwUThere is nothing in Webstation logs.
Jure
ParticipantNo I only have RS 6 installed.
URL to connect is: http://localhost:10000/
Port is the same as in Webstation -> Application options
November 21, 2022 at 1:04 pm in reply to: Export channel data to excel for longer periode of time #11633Jure
ParticipantI am asking about Rapid SCADA 5, if there is any solution to export data.
November 18, 2022 at 11:48 am in reply to: Export channel data to excel for longer periode of time #11580Jure
ParticipantHi, we don’t want to limit it but lets say export data for one or multiple channels to excel for whole year.
Jure
ParticipantSo no posible fix / solution in this version?
Jure
ParticipantNo loading in not successful. You need to refresh web page, before you can open any scheme. Before that problem occurs scheme will open in around 3s. It doesn’t matter if you are in LAN or internet, for the problem to occur.
On Windows Server it appears to be OK. Scheme sizes are around 1300 kB.Jure
ParticipantThank you for quick response, problem was ignoring keys on upload.
Jure
ParticipantThere was problem with images in last post:
https://ibb.co/6yMsDxK
https://ibb.co/tZyBYP2
https://ibb.co/VWtD9R7Jure
ParticipantHello,
here are the images requested:Could be problem connected with using MQTT communication?
Regards,
Jure-
This reply was modified 4 years, 3 months ago by
Jure.
Jure
ParticipantHello,
verison is 5.2.5.3.Jure
ParticipantWe have a separate vision program that scans image of GUI from HMI and generates a file where it says that at x-y position is some element.
Then we have a program that would generate interface file with position of all element so that person should just have to enter Input channel.
Both are custom programs build by our company. -
