Automation plugin channel data change trigger
Forum Home Forums Understanding the Software Automation plugin channel data change trigger
  • #10489
    Jure
    Automation plugin channel data change trigger is triggered on server start / restart. I don’t think that this is correct behavior.Because I have around 40 such triggers for variables that represent errors and I attached send mail command. So at every server restart I get 40 mails. Is there any simple workaround?
    #10490
    Which version of Automatic Control Module do you use?
    Currently, the state of the triggers is stored on disk and restored on restart.
    #10493
    Jure
    verison is 5.2.5.3.
    #10501
    5.2.5.3 is up to date.
    Could you provide screenshots of the trigger, the input channel properties and a part of the log of Automatic Control Module?
    #10510
    Jure
    here are the images requested:
    Could be problem connected with using MQTT communication?
    Regards,
    Jure
    • This reply was modified 3 years, 10 months ago by Jure.
    #10512
    Jure
    There was problem with images in last post:
    https://ibb.co/6yMsDxK
    https://ibb.co/tZyBYP2
    https://ibb.co/VWtD9R7
    #10513
    On the screenshot you use “On channel data change” trigger. Triggers of this type don’t save their state on Server restart.
    Depending on channel properties, consider using “On channel data” triggers.
