hicode
  • in reply to: Toggle color #7051
    hicode
    I don’t get it.
    But for exemple here you have one toggle (on) and another (off) in a table view.
    Is that you wanted?
    in reply to: Toggle color #7048
    hicode
    Yep i have uploaded the project and i’m sure too for the values of holding registers
    in reply to: Call command from formula #7037
    hicode
    Ok, thanks
    in reply to: Toggle color #7036
    hicode
    I have tried it but it doesn’t change anything..
    in reply to: Error state on device #7031
    hicode
    hi,
    are you sur that your device adress is good ? i see “2” for you, have you try with 1 ?
    in reply to: Toggle color #7026
    hicode
    No problem, so there is the pic : here .
    • This reply was modified 6 years, 3 months ago by hicode.
    in reply to: ModAlarm #6739
    hicode
    Yes, may be the Notification Plugin will help but first i wanted to try using AlarmMod but thank’s.
    Yes i see i have NAudio.dll and unblocked it..
    I will follow your advise and send a message on Github !
    in reply to: OPC Server list #6717
    hicode
    Ok i have found ..
    Its not a OPC Server but a OPC UA so i need to choose the good device.
    It work now with device OPC UA.
    Sorry for my mistake !
    in reply to: OPC Server list #6716
    hicode
    With BrowseOPC i dont see it neither..
    But with “UAExpert” i see it.
    I have followed this guide to make my OPC Server test : Youtube
    You thinks its not a good guide? Or i miss something ?
    in reply to: DemoProject not working #6701
    hicode
    Ok thank you for your answer, Modbus work now. I have another problem but i will create a new topic.
    in reply to: DemoProject not working #6673
    hicode
    The project name is : “DemoProject.en-GB.rsproj” .
    And i have installed the latest version here https://rapidscada.org/download-all-files/download-rapid-scada/
    So its the 5.8.0.
    But in the Administrator its the 5.5.2.0 Version !
    in reply to: Building the app error #6313
    hicode
    Its okay now, i have replaced the dll5 by the classic dll and it work’s !
    Thanks for help
    in reply to: Building the app error #6310
    hicode
    i tried but the error dont want to leave me i think
    screen : https://ibb.co/QX14bNP
    • This reply was modified 6 years, 9 months ago by hicode.
    in reply to: Building the app error #6299
    hicode
    also this screen : https://ibb.co/njVq4nL
    in reply to: Building the app error #6298
    hicode
    I put the screen here : https://ibb.co/SVRLzXN
    thanks
