Hello! Need help with create Scheme Templates for thermostats (it’s over 7). In Template i wrote input channel 101 for temperature, output channel 102 for setpoint, and output channel 109 for turn on/off fancoil from thermostat. After that in the Interface in the Arguments i wrote cnlOffset for each thermostat.
All input channels of every thermostat i see without problem (it’s temperature). But when i send command to output channel, it’s send to output channel from Template (102, 109). Need to send command to every thermostat with offset channel. Need to help to solve this problem.
