ModAlarm
  • #6731
    hicode
    I’m trying to setup ModAlarm, i have included the files and unblocked it.
    But i have a problem when i want to add a sound. (See img)
    modAlarm
    Its in french but it say : cant load the file/assembly ‘NAudi…. Or one of his dependencies. The file is unfindable.
    And for information you have a little mistake on Cancel is written Cansel.
    Thanks for help
    • This topic was modified 6 years, 5 months ago by hicode.
    #6735
    Seems like it uses a DLL that is not found. I suppose, you should send a message to an author of the module on GitHub.
    May be Notification Plugin can help to solve your task.
    #6736
    NAudio.dll is in modalarm-1.2.3.zip
    Try unblocking it.
    #6739
    hicode
    Yes, may be the Notification Plugin will help but first i wanted to try using AlarmMod but thank’s.
    Yes i see i have NAudio.dll and unblocked it..
    I will follow your advise and send a message on Github !
