Toggle color
Viewing 10 posts - 1 through 10 (of 10 total)
  • #7021
    hicode
    i’m communicating with a ModBUS I/O.
    I use Toggle button to send command and read holding register.
    It work’s fine, but i have a graphic issu.
    When the switch is on, it’s supposed to be green but it keep black, it only switch the position.
    In background color i have “Status”.
    It’s a bug ? Or a PEBCAK ?
    • This topic was modified 6 years, 3 months ago by Mikhail.
    #7024
    Please make screenshots of the input channels and the toggle properties.
    #7026
    hicode
    No problem, so there is the pic : here .
    • This reply was modified 6 years, 3 months ago by hicode.
    #7034
    Change channel type to Discrete
    #7036
    hicode
    I have tried it but it doesn’t change anything..
    #7039
    Did you upload the project after change?
    Create a table view to check color of values.
    #7048
    hicode
    Yep i have uploaded the project and i’m sure too for the values of holding registers
    #7049
    #7051
    hicode
    I don’t get it.
    But for exemple here you have one toggle (on) and another (off) in a table view.
    Is that you wanted?
    #7052
    The values in the table, also black, not red and green. This means that input channels are not configured properly. You should also set the Unit field to Off-On.
