Call command from formula
Forum Home Forums Understanding the Software Formulas Call command from formula
  • #7030
    hicode
    I’m asking myself.. Can we call a cmd from formula?
    Exemple :
    I click on a button, it send a command (Signal 1), in the command formula I do some maths and I want to send another command on a different signal (Signal 2).
    I don’t find ressource on that..
    Thank you !
    #7035
    You need Automatic Control Module for this purpose.
    #7037
    hicode
    Ok, thanks
    #7519
    yuemiao
    I have a situation:I want call a command but the command value is determined by one input channel value.At first,I want realize it in formula,but how to call a command from formula?if I realize it in Automatic Control Module,but how to set command value that varies according to the input channel?What should I do?
    #7523
    When a command is sent, a formula of a related output channel is calculated.
    You can take input channel value in the formula of the output channel.
    Simple example: Val(101) * 10
    where 101 is the input channel number.
    #7524
    You right, Automatic Control Module is needed if you send commands according to conditions.
    #7529
    yuemiao
    How can I take the command value that I send in output channel formula?The original value is also one of the options.
    #7536
