MikhailModeratorYes, you need Rapid Gate for each remote server. The module price is reasonable and competitive. Before paying, get the trial keys for testing.
MikhailModeratorCreate a new function and set multiple SetVal inside it. For example,
public double MySetVal() { SetVal(101, 0); SetVal(102, 0); return Cmd; }Then specify MySetVal() in the output formula of the channel.
This reply was modified 2 years, 8 months ago by
October 23, 2023 at 7:38 am in reply to: Add OPC DA error:’OpcRcw.Comn.IOPCServerList2′ No such interface supported #13537
Are the counter channels connected to hardware counters?
How do you reset a single counter?
MikhailModeratorExtended support service can be useful for the complex system.
Thank you for the clear description of the system.
Yes, Rapid SCADA is designed to support such architecture.
I suggest to configure remote and central Rapid SCADA instances within the same project. Then use Rapid Gate module to sync them.
Choose Rapid SCADA 6 version, because Rapid Gate was significantly improved for v6.October 20, 2023 at 9:52 am in reply to: Add OPC DA error:’OpcRcw.Comn.IOPCServerList2′ No such interface supported #13531
MikhailModeratorPossible cause is that OPC Core Components are not installed. Download them from Rapid SCADA or OPC Foundation website and install.
October 19, 2023 at 8:25 am in reply to: error: Scripts is inaccessible due to its protection level #13527
MikhailModeratorYou need
public double DT()...
User’s functions should be declared as public in v6.
Free charts are available out of the box. No additional configuration needed.
MikhailModeratorYou should create a more complex function and use it inside EverySec, e.g.,
EverySec(() => MyFunc)
MikhailModeratorError text was not informational. However, timeout is set for the request when it is created.
Headers should work. Play with them.
MikhailModeratorCheck the device timeout. It should be > 0.
MikhailModeratorTry simplifying the request and arguments to find the error cause.
MikhailModeratorCannot reproduce: https://ibb.co/S0sW3Tm
My DrvHttpNotif_XXX.xml is
<?xml version="1.0" encoding="utf-8"?> <NotifDeviceConfig> <Uri>http://remote:Hovdetjenn18@10.147.19.135/scada-remote?m=json&r=grp&fn=write&alias={grp}&value={value}</Uri> <Method>Get</Method> <Headers /> <Content /> <ContentType /> <ContentEscaping>None</ContentEscaping> <ParamEnabled>true</ParamEnabled> <ParamBegin>{</ParamBegin> <ParamEnd>}</ParamEnd> <AddrSep>;</AddrSep> </NotifDeviceConfig>Command string data:
value=34 grp=63/7/200
MikhailModeratorAutomatic Control Module can activate trigger with timeout. But currently the module cannot generate events. If we add to the module a feature to generate events on trigger, does it solve the issue?
