Using Formulas With Scripts
Forum Home › Forums › Understanding the Software › Formulas › Using Formulas With Scripts
  • #13497
    DHague
    I have a channel with a formula that needs to be activated at a regular interval this seems to be provided with the “EverySec” function in the “Timers” script. For example, I want to be able to have the following formula:
    EverySec(SetVal(101, Val()+1:Val()))
    However, this causes an error. Some clarification on how this functionality is achieved would be helpful.
    Thanks.
    #13501
    If you use this formula inside the channel 101, try
    EverySec(() => { return Val() + 1; }) or
    EverySec(() => Val() + 1)
    The channel should be of the Calculated type.
    • This reply was modified 3 years, 1 month ago by Mikhail.
    #13504
    DHague
    Is there a way to edit the script to make it update every half second instead of every second?
    #13505
    DHague
    • This reply was modified 3 years, 1 month ago by DHague.
    #13511
    Open the Scripts table and check the EveryPeriod method. You can use it instead of EverySec.
    #13519
    DHague
    Thanks for the info,
    I have been trying to figure out how to get the channel to stop counting at a maximum value, using limits to do this has proven to be non-functional even when tied to the channel. Currently I have the E. Low and the Low set to 0, the High and E. High set to 165, and the dead band set to 1. Is there a way to have my channel stop counting once it reaches 165 using limits or is that under a different function?
    #13521
    You should create a more complex function and use it inside EverySec, e.g.,
    EverySec(() => MyFunc)
