Viewing 15 posts - 901 through 915 (of 6,288 total)
  • Mikhail
    Also check the communication line log after sending a command to get a error message.
    Please provide a screenshot of the Modbus template.
    That’s true.
    New Scheme Editor for version 6 is under development.
    Check the version history.
    in reply to: Request to Upload RapidSCADA 6.0 Videos to Bilibili #15191
    Many developers in China are unable to access YouTube due to network restrictions. To help them, I kindly request permission to upload the RapidSCADA 6.0 video tutorials to Bilibili, a popular video platform in China.
    I assure you that all copyrights will be respected. The original content will remain unaltered, and full credit will be given to RapidSCADA, including links back to the original videos.
    Yes, you can upload the videos providing the original links.
    Is there an option to download videos from Youtube automatically and upload to another hosting?
    in reply to: New release Rapid SCADA 6.3.x #15190
    Backward compatibility is provided for data archives.
    You need to update all files, not only binaries.
    in reply to: Modbus to Rapid Scada to PLC #15178
    it asks me in addition to the IP address and port of the server, the address of the device (from 1 to 247) and the number of the register.
    Default TCP port is 502 for Modbus. Address is 0 in your settings. But I suggest to change it to 1. Register addresses are shown in the Modbus template on your screenshot.
    in reply to: Modbus to Rapid Scada to PLC #15176
    Thank you for your positive feedback.
    I strongly recommend to upgrade to Rapid SCADA 6. We significantly improved Modbus Slave driver to make it easier to configure. Is it possible for you to upgrade and then discuss the up to date version?
    • This reply was modified 1 year, 10 months ago by Mikhail.
    in reply to: SCADA 6.2.0 “Server is unavailable.” #15175
    Server 5 and Server 6 must use different TCP ports to be able to work in parallel. Client applications should connect to a proper TCP port.
    in reply to: New release Rapid SCADA 6.3.x #15174
    does updating from 6.1 to 6.3 require data imigration ?
    Projects are compatible. Project migration is not needed.
    How to pack souce rapidscada code project to installation .exe file setup ?
    Build the source code according to the instructions. Then copy the files from your build output to the necessary folders.
    in reply to: Auto control module not loading #15163
    Please provide screenshots of the Administrator app version and the module version when you select the module in the Administrator.
    in reply to: The linux device is not connected #15162
    Likely, it should be connected to the Linux server where the Communicator service is working.
    in reply to: SCADA 6.2.0 “Server is unavailable.” #15161
    According to the logs, Rapid SCADA 6 works well. But you open Rapid SCADA 5.
    Try http://localhost:10008 (by default)
    in reply to: Modbus to Rapid Scada to PLC #15160
    You can set Modbus ID in the device options (Communicator app). Unit ID = 1 is the most popular. Could you provide screenshots of your settings?
    Could you clarify your question by providing screenshots?
    in reply to: RapidGate from Rapid SCADA 6.3.0 to Rapid SCADA 6.2.1? #15157
    Probably, you can. The project format and communication protocol are compatible.
    in reply to: Auto control module not loading #15147
    We upload the latest version of the applications and modules on the website. If you need a certain version of a module, use Module Store.
