Auto control module not loading
Forum Home › Forums › Uncategorized Issues › Auto control module not loading
  • #15133
    r1moore
    I am getting the following error when trying to view the properties of the automatic control logic module after activating it in the admin app:
    error loading module configuration: root element is missing
    I have verified that the auto control module files are unblocked and added my registration key. I noticed the ModAutoControl config file is empty, could this be causing the error?
    #15145
    Yes, this is the cause of the error. Make sure that the module version is compatible with the Rapid SCADA version. I recommend to update the both by downloading them from our website.
    You need to restore the module configuration from a backup copy. A file copy also can be found at SCADA\ScadaServer\Config (working copy of the configuration)
    #15146
    Check this link.
    #15147
    We upload the latest version of the applications and modules on the website. If you need a certain version of a module, use Module Store.
    #15150
    r1moore
    I have verified the versions are compatible. I noticed every time I upload the configurations in the admin app it erases the contents I added to the ModAutoControl config file and leaves it blank. Any idea why this would be happening?
    #15151
    r1moore
    I also get the following error when saving commands.
    Error saving module configuration:
    Method not found: ‘System.Xml.XmlElement Scada.ScadaUtils.AppendElem(System.Xml.XmlNode,System.String,System.Object)’.
    #15163
    Please provide screenshots of the Administrator app version and the module version when you select the module in the Administrator.
    • This reply was modified 2 years, 2 months ago by Mikhail.
    #15168
    Update the module, this is a bug on version 6.3.0 when using the module from 6.2.1
