Forum Home › Forums › Communicating with Devices › Modbus › Modbus to Rapid Scada to PLC
- This topic has 9 replies, 4 voices, and was last updated 2 years, 2 months ago by
July 17, 2024 at 7:20 am #14967
rapidscadaaks
ParticipantNeed help
There are about 40 Modbus devices (Meters, UPS, etc) connected to Rapid Scada. I would like that data of all the devices when received by Rapid Scada be also sent by Rapid Scada to the PLCs simultaneously for processing by the PLC. There are 3 PLCs and Modbus data of certain devices is to be sent to the defined PLC. PLCs are to only Read and not Write data back to the Modbus devices.July 17, 2024 at 8:02 am #14968
manjey73ParticipantPLCs are to only Read and not Write data back to the Modbus devices.
Please translate, or draw a diagram of the interaction?
Do you have 3 PLCs but you can’t transfer data from others into them, but they can take data from Scada? – then use Modbus Slave
Do you have 3 PLCs and can you write Scada data in them? – then you need an Auto-Control ModuleJuly 17, 2024 at 12:32 pm #14976
More info needed.
Are those 3 PLCs operate as Modbus master (client) or Modbus slave (server)?July 17, 2024 at 12:51 pm #14977rapidscadaaks
ParticipantHi
Thanks for the tip. I have been to find a solution by using Modbus Slave functionality of Rapid Scada.
This solution however needs to be tested with 15 devices and I will update the results in few days.
Many thanks
July 18, 2024 at 9:56 am #14982
Good.August 16, 2024 at 12:36 pm #15148
IT0508ParticipantHi, how did you do it? I downloaded the modbus slave driver trial because I have to transmit a 0 – 1 signal from a SCADA input channel to a datalogger via modbus TCP to control its relays but for now I have not succeeded… Furthermore I have no idea what modbus address to give to the datalogger to be able to read the data from SCADA, and what modbus ID does Scada have? I don’t understand anything… I looked for answers on the forum but I found nothing
Please help me
This reply was modified 2 years, 2 months ago by
IT0508.
August 19, 2024 at 8:15 am #15160
MikhailModeratorYou can set Modbus ID in the device options (Communicator app). Unit ID = 1 is the most popular. Could you provide screenshots of your settings?
August 19, 2024 at 8:42 pm #15170
IT0508ParticipantHi Mikhail, first of all I want to thank you for your support to rapid scada users it’s fantastic! I’m happy to spend my money on a program developed by such dedicated people.
Anyway I created a new line as “TCP SERVER SLAVE” with a device “KpModbusSlave.dll”, I tried to create the output channels with the dll file but I get a programming method equal to the one I did to read data from other modbus devices, equal to “KpModBus.dll”. I would like my datalogger with IP address 192.168.0.40 and with modbus ID 1 to read the data of the various input channels of rapid scada, but to do so it asks me in addition to the IP address and port of the server, the address of the device (from 1 to 247) and the number of the register. In addition to not finding this data, the device I created as a tcp server slave does not read any value from input channels…I attach, as you asked, the photos of my configurations so that you can better understand my problem.
https://ibb.co/VxP6gcZ
https://ibb.co/H4RQWvC
https://ibb.co/HTcnz9W
https://ibb.co/hKcVBmd
https://ibb.co/F6sZvcm
https://ibb.co/HzZYWvBAugust 20, 2024 at 9:26 am #15176
Thank you for your positive feedback.
I strongly recommend to upgrade to Rapid SCADA 6. We significantly improved Modbus Slave driver to make it easier to configure. Is it possible for you to upgrade and then discuss the up to date version?-
August 20, 2024 at 9:29 am #15178
MikhailModeratorit asks me in addition to the IP address and port of the server, the address of the device (from 1 to 247) and the number of the register.
Default TCP port is 502 for Modbus. Address is 0 in your settings. But I suggest to change it to 1. Register addresses are shown in the Modbus template on your screenshot.
