Viewing 15 posts - 4,696 through 4,710 (of 6,290 total)
  • in reply to: Display and Set the String Value for tag #4124
    Your formula is incorrect for binary command. It have to return array of bytes. Instead of CmdVal you need CmdData variable. I can write you a correct formula for a fee. Creating formulas is out of free support.
    in reply to: Rapid Scada Update and license key #4123
    Try the same configuration of Rapid SCADA on another computer to check if this issue constantly appears or depends on the particular PC.
    in reply to: Adding link to chart view #4119
    To use a link you need to update Rapid SCADA to the latest version.
    in reply to: Adding link to chart view #4118
    I see.
    Quick solution is using a link component on a scheme and specify an URL to a chart.
    The best solution is updating the web application to support the appropriate option. This could be done on commercial base.
    in reply to: Display and Set the String Value for tag #4117
    Most likely.
    in reply to: Rapid Scada Update and license key #4116
    Please remind what is the version of SCADA-Server now? I strongly recommend 5.1.0.4
    in reply to: Mail SMTP Set #4110
    Go to gmail account settings. Open the “Forwarding and POP/IMAP” tab and try enabling POP.
    in reply to: Display and Set the String Value for tag #4109
    Provide screenshots please.
    in reply to: Rapid Scada Update and license key #4106
    You can also update by replacing files, but it’s easy to make a mistake.
    in reply to: Rapid Scada Update and license key #4105
    1. You should post here a part of Server log.
    2. Please send me the new computer code by email. I will check the changes.
    Is there another way to back up and restore the license more quicly and safety?
    The key becomes invalid because of some changes in the environment. I will check them when receive the new computer code.
    Is there the way to update software to new version more convenience?
    The recommended way is here as you noticed.
    in reply to: Scada development #4102
    in reply to: Project copy from pc to pc #4101
    There are different ways:
    1. The manual
    2. The Agent app
    3. When the new Administrator is complete, it will be easy. Planned in the next year.
    in reply to: ScadaSchemeEditor – Button use #4096
    You can create complex functions to use in formulas, so there is enough tools to do what you need.
    in reply to: ScadaSchemeEditor – Button use #4095
    A command is bound to an output channel. The output channel has only 1 formula. So you should do all the required calculations in a one formula. Depending the pressed button, you get CmdVal = 0,1,2,… that you can use in the formula.
    in reply to: ScadaSchemeEditor – Button use #4088
    Can I define different buttons using different formulas in the same Number (19)?
    A set of buttons is fixed for an output channel.
