I have a Input channel (Calculated real , ASCII text), then I create a output channel to set string text for input channel use formular:SetVal(222, CmdVal),but when I set string value, it is display:”Incorrect command value.”! Can you suggess the solution for this.
You use a standard command, and it takes numeric values. Probably it is necessary to use a binary command and convert the string representation to hex with a formula ?Maybe that’s the reason.
Hi, command type of output channel change to binary. Error of Scada server as below:
2018-08-11 08:08:41 <HN3521><SYSTEM><ACT> Users are read from the configuration database
2018-08-11 08:08:41 <HN3521><SYSTEM><ACT> Formulas are read from the configuration database
2018-08-11 08:08:41 <HN3521><SYSTEM><ERR> Error compiling the source code of the formulas:
Line 602, column 103: error CS0029: Cannot implicitly convert type ‘double’ to ‘byte[]’
2018-08-11 08:08:41 <HN3521><SYSTEM><ERR> Normal program execution is impossible.
Your formula is incorrect for binary command. It have to return array of bytes. Instead of CmdVal you need CmdData variable. I can write you a correct formula for a fee. Creating formulas is out of free support.
