Mail SMTP Set
Forum Home › Forums › Uncategorized Issues › Mail SMTP Set
Viewing 15 posts - 1 through 15 (of 18 total)
  • #3330
    leon
    HI
    https://imgur.com/a/JGdQc
    Please guide setting method Thanks!!
    #3331
    Joao
    You can create a email group in Communicator> Device Libraries > double click KpEmail
    then just send a command type 1 (binary) with this content:
    group_name; subject; message
    #3332
    Joao
    You can use the module Automatic Control to send Emails automatcly. This can help: http://doc.rapidscada.net/content/en/modules/mod-auto-control.html
    #3335
    See the description at Device Libraries – KpEmail.dll
    You need a Binary command number 1 with a text that Joao noticed above.
    • This reply was modified 8 years, 6 months ago by Mikhail.
    #3337
    leon
    Joan
    Thank you for your reply but I’m still trying
    #3340
    leon
    Hi Mikhail
    I’m sorry I don’t really use
    Is there a similar setting reference?
    Administrator>Devices>Call unmber need set email?
    Communicator>Line 4>Request Sequence>Call unmber and Command line need set??
    https://imgur.com/a/DSRDb
    #3342
    Joao
    you are sending a command type Standard, It have to be binary
    this is my configs:
    https://imgur.com/a/CPKHb
    • This reply was modified 8 years, 6 months ago by Joao.
    #3350
    leon, first of all, make sure that you can successfully send emails from Communicator. You don’t need other apps for testing, just Communicator. Send commands from the Command tab.
    After you send emails from Communicator, you will setup Administrator and Automatic Control module.
    #3358
    leon
    hi
    Email has not been sent yet
    https://imgur.com/a/tDWns
    Thank you very very much for your answers
    #3362
    So at the first, you should fix sending using Communicator only.
    #3365
    leon
    hi
    I succeeded Thank you all!!
    Sending email notifications.
    Commands:
    1 (binary) – send the notification.
    Command text examples:
    group_name;subject;message
    contact_name;subject;message
    email;subject;message
    #3368
    Great 🙂
    #4108
    Gonederra
    I’ve got some probems with the SMTP server. It gives me this error:
    Error sending email to *****@gmail.com: El servidor SMTP requiere una conexión segura o el cliente no se autenticó. La respuesta del servidor fue: 5.5.1 Authentication Required. Learn more at
    It is translated to, the connection is not safe or the client could not be authentified.Am I configuring something wrong or is it something else?
    I am just trying to send an email via Communicator with the commands as it is specified before in this thread.
    Thanks.
    #4110
    Go to gmail account settings. Open the “Forwarding and POP/IMAP” tab and try enabling POP.
    #5266
    jsanjose
    I’m experiencing the same problem.
    Using Communicator I’m sending a test message using a gmail account. The log response is 5.5.1 Authentication Required. It’s a config problem.
    Using SSL on SMTP Gmail server doesn’t work, using smtp.gmail.com on port 578 since this is de STARTTLS port. Nevertheless, 465 port doesn’t work neither (time exceded error).
    Any ideas?
    Thanks in advance.
