Rapid Scada Update and license key
Forum Home › Forums › Runtime Bugs › Server Bugs › Rapid Scada Update and license key
Viewing 14 posts - 1 through 14 (of 14 total)
  • #4103
    catcute
    Dear Mikhail
    I has 2 issues:
    + I have problem with Rapid Scada, after 1 or 2 days work, when I restart or stop Scada Sever, it is keep status “pending stop”, Scada Server log that: it is only keep write data to current data, then waiting long time still can not solve problem, only I restart the computer then it work again.
    + I’s just updated Rapid Scada to Rapid SCADA 5.5.3, I follow this instruction:
    http://doc.rapidscada.net/content/en/installation-and-run/software-update.html.
    After update I have problem with license key. I must install again Automation Control module, enter the key -> it is ok, but with telegram communication plugin, when i insert the key -> it is show invalid key (and the computer code different with old one??). I make the backup for Scada before make update, how can i solve the license problem of telegram communication plugin? Is there another way to back up and restore the license more quicly and safety? Is there the way to update software to new version more convenience?
    Thank you!
    • This topic was modified 8 years, 2 months ago by Mikhail.
    #4105
    1. You should post here a part of Server log.
    2. Please send me the new computer code by email. I will check the changes.
    The key becomes invalid because of some changes in the environment. I will check them when receive the new computer code.
    The recommended way is here as you noticed.
    #4106
    You can also update by replacing files, but it’s easy to make a mistake.
    #4114
    catcute
    Hi Mikhail
    Last time, I have the trouble when stop Scada Server-> it keep stop pending untill I restart the computer. I think my computer have the virus (some files was damaged by virus). Then I install window ,Rapid and update the scada config again but it can not solve problem. If Sacda server run 8 hours or less, it can stop and start ok. If server run over 15 hours, the problem happen!!?
    Scada Server stop pending
    I install the RS on the cloud VPS windows.
    when stop pending, Scada server still log:
    2018-08-10 16:05:33 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:06:20 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:06:36 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:06:43 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    Full log:
    2018-08-10 16:00:02 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:02 <HT-PC><SYSTEM><ACT> Command 0x03 (write current data) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Command 0x03 (write current data) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Command 0x03 (write current data) is received from the client 127.0.0.1
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:06 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:06 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:06 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:07 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:07 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:08 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:08 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:09 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:09 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:10 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:10 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:11 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:45 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:46 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:46 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:47 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:47 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:48 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:48 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:49 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:49 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:50 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:50 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:51 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:51 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:52 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:52 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:53 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:53 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:54 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:54 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:55 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:55 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:56 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:56 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:57 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:57 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:58 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:58 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:59 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:59 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:19:00 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:19:00 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:19:00 <HT-PC><SYSTEM><ACT> Writing snapshot in the minute data table is completed
    2018-08-10 16:19:00 <HT-PC><SYSTEM><ACT> Writing snapshot in the minute data copy table is completed
    2018-08-10 16:19:01 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:19:01 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:19:02 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:19:02 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:19:03 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:19:03 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    #4116
    Please remind what is the version of SCADA-Server now? I strongly recommend 5.1.0.4
    #4121
    catcute
    Yes, I updated to last version 5.1.0.4 but the same problem.
    #4123
    Try the same configuration of Rapid SCADA on another computer to check if this issue constantly appears or depends on the particular PC.
    #4127
    Do you use Automatic Control module?
    #4128
    catcute
    –> yes, I use Automatic Control module and update to last version.
    I try the same config on another computer, it run with no problem. But when I run this config on Cloud VPS windows, the problem happen.
    #4131
    If you switch off Automatic Control Module, does the problem appear?
    #4132
    catcute
    It look like problem from Automatic Control Module, after I remove this module, problem not happen again. Althought I’ve not setting for this module yet.
    #4138
    Can you post here a link to download the full log folder of SCADA-Server when the issue occurs?
    The thing is that stopping procedure is simple, and it’s strange that the service can’t stop.
    #4139
    catcute
    Because server has run for serveral days, The log file was filled with new data. I can not see the time when problem happen.
    #4140
    OK,
    If it occurs again, please send me the log folders.
