MikhailModeratorFormula of output channel is calculated in a moment when a command is sent.
MikhailModeratorCan I use ‘Formulas’ also for this purpose?
What purpose?
Does it work in output formula field?
Such formula will work. But CustomFormula() == 1 …
MikhailModeratorwhen some device logon or logoff
How a device do this?
MikhailModeratorEach topic should describe only 1 question.
Please create a separate topic for the second question.
And provide examples for the both cases to make them clear.
MikhailModeratorTry removing ScadaWebCommon5 dependency. Does it help?
You should create a time trigger as usual. Then in the output channel formula, check
Val(101) < -10 ? Cmd : double.NaNdouble.NaN cancels the command.
MikhailModeratorI’ve realized that the address must be added by 1 since rapidscada address starting from 1 and device address starting from 0.
You can change the starting address in the template settings.
MikhailModerator🙂
MikhailModerator1. “easy modbus client” – is this a library or an application?
2. Talking about Comap: “It is possible to disable requiring the access code in
the configuration web page.” It’s from the manual.3. We can update the existing Modbus driver to send access code as a custom development.
I think, it’s possible to develop a plugin that writes user ID and username into specified input channels when a user logged in.
If you are a developer, you can do it by yourself. Or you can order development.
MikhailModeratorCould you provide an example of correct communication? I mean content of packets.
Many controllers support disabling of protection by a code.
No, sorry.
If needed, I can research whether it’s possible to implement this feature by development a custom plugin.
Anyway, an input channel may contain only 8 Latin characters.
MikhailModeratorand now I can use more easily ElasticReport with the calcType=”Diff”
Nice that simple solution is possible.
Formulas like “=SUM(RC[-3]:RC[-2])” generated by Excel. It’s impossible for human 🙂
You can set it in the formula of output channel in Administrator.
For example, you can write a number there.
MikhailModeratorYou should check the dependencies. There are no magic.
