Forum Home › Forums › Communicating with Devices › Modbus › Device error: [02] ILLEGAL DATA ADDRESS!
- This topic has 7 replies, 2 voices, and was last updated 6 years, 10 months ago by
December 29, 2019 at 12:03 pm #6286
KHSaville
ParticipantIt took a while to learn Rapid Scada but well worth it.
We need to read modbus registers from a gas meter, electric meter and a Comap generator controller – IS-NT-BB.
Modbus RTU on serial line with rs485 converter works perfect.
However I am unable to get TCP to work with the Comap.
They require -“Every Modbus/TCP session has to be started with writing the access code from the Modbus/TCP client to the controller. If the session is closed and reopened again the access code must be written again” I am trying to send access code 0 (zero) and cannot get this to work. I send command 7 to 6339 – can you help? If I use a free easy Modbus client it works.December 30, 2019 at 12:47 pm #6288
MikhailModeratorCould you provide an example of correct communication? I mean content of packets.
Many controllers support disabling of protection by a code.December 30, 2019 at 2:38 pm #6290KHSaville
ParticipantWith Rapid Scada
Send (12): 00 00 00 00 00 06 01 03 00 0D 00 01
Receive (7/7): 00 00 00 00 00 03 01
Receive (2/2): 83 02
with easy modbus client
Tx: 00 03 00 00 00 06 01 06 18 C2 00 00
Rx: 00 03 00 00 00 06 01 06 18 C2 00 00
Tx: 00 04 00 00 00 06 01 03 00 0D 00 01
Rx: 00 04 00 00 00 05 01 03 02 01 69
Tx: 00 05 00 00 00 06 01 03 00 0D 00 01
Rx: 00 05 00 00 00 05 01 03 02 01 69
Tx: 00 06 00 00 00 06 01 03 00 0D 00 01
Rx: 00 06 00 00 00 05 01 03 02 01 69
My problem is I am unable to send the access code – my error is either Output channel number 1 but where do I put “Command number” and set the value 0 (zero).
https://drive.google.com/open?id=1szde5yIYuH2lN-DjpSX6dy1VWSSolxc5December 30, 2019 at 3:14 pm #6291KHSaville
ParticipantIf I do not sent the access code – it fails as with Rapid Scada
Tx: 00 09 00 00 00 06 01 03 00 0D 00 01 – read holding register
Rx: 00 09 00 00 00 03 01 83 02 – rejected
Tx: 00 0A 00 00 00 06 01 03 00 0D 00 01 – read holding register
Rx: 00 0A 00 00 00 03 01 83 02 – rejected
Tx: 00 0B 00 00 00 06 01 06 18 C2 00 00 – write single register
Rx: 00 0B 00 00 00 06 01 06 18 C2 00 00
Tx: 00 0C 00 00 00 06 01 03 00 0D 00 01 – read holding register
Rx: 00 0C 00 00 00 05 01 03 02 01 69 – correct response!December 31, 2019 at 8:24 am #6294
MikhailModerator1. “easy modbus client” – is this a library or an application?
2. Talking about Comap: “It is possible to disable requiring the access code in
the configuration web page.” It’s from the manual.3. We can update the existing Modbus driver to send access code as a custom development.
December 31, 2019 at 3:44 pm #6295KHSaville
ParticipantMany thanks again – Happy new year Mikhail!
1.http://easymodbustcp.net/en/ – free app.
2. I will try that.
3. If I can write commands to turn on and off bits, write values to registers
I should be able to write the access code.January 1, 2020 at 7:24 am #6296KHSaville
Participant2. Found it !
WOW – now got a talking Comap !
You Sir, are a hero.January 3, 2020 at 7:13 am #6303
MikhailModerator🙂
