Automatic Control Module – Multiply triggers
Forum Home › Forums › Understanding the Software › Automatic Control Module – Multiply triggers
  • #6297
    athes
    Hi Mikhail,
    Is there any solution how to combine different triggers before sending a command?
    I want to use Time trigger & value trigger together:
    If the (time is 13:00) AND a (specific value is < -10) then send a command (only once in a day)
    Thanks.
    #6305
    You should create a time trigger as usual. Then in the output channel formula, check
    Val(101) < -10 ? Cmd : double.NaN
    double.NaN cancels the command.
    #6312
    athes
    Wow, what a magic. It works, thank you!
    Can I use ‘Formulas’ also for this purpose? If yes, how? (my formula returns with a 0 or 1)
    Does it work in output formula field?
    CustomFormula(Val(101), Val(102), Val(103)) = 1 ? Cmd : double.NaN
    #6314
    What purpose?
    Such formula will work. But CustomFormula() == 1 …
    #6315
    Formula of output channel is calculated in a moment when a command is sent.
    #6317
    athes
    Got it, thanks.
