MikhailModeratorAll *.sh files should be executable. Not only svc_restart.sh
I suggest to run make_executable.sh
Check the settings:
https://ibb.co/hKd7VfT
MikhailModeratorCould you provide a screenshot of *.sh file attributes?
It would be better to solve it.
Try port 25
MikhailModeratorAll *.sh files inside the scada directory must be executable.
You could run make_executable.sh to make them executable.
MikhailModeratorIs there 100% correlation between long waiting for response in Administrator and the “Error controlling service” message?
Check Linux attributes of the file /opt/scada/ScadaServer/svc_restart.sh
Is it executable?
As I understand, Google does not allow 3rd party application to send emails any more.
You should use another email service.
For example, in my country https://yandex.com is popular.
Mail servers may use various server host and port, different than Google. Check their manuals.-
This reply was modified 4 years ago by
The ScadaAgent service works on Raspberry, keeps the TCP port 10002 open, and waits for connections.
Probably, when you get an error, the ScadaAgent service is not available.
If the problem repeats, check the Agent’s log file in the directory /opt/scada/ScadaAgent/Log
MikhailModeratorCould you describe your software? How does it work?
Duplicated component IDs may cause unexpected behavior of Scheme Editor.
If you generate a scheme by some tool, you should provide unique component IDs.
In the Modbus template set the required element type.
MikhailModeratorAlso try to request 1 register instead of 34 for testing.
“[0A] GATEWAY PATH UNAVAILABLE!” is returned by a device. So you successfully communicate with a gateway at least.
Use Modbus Parser to check your request: 00 CD 00 00 00 06 01 03 0B CB 00 22
May be you need to change Unit ID (the address field). -
