Viewing 15 posts - 2,341 through 2,355 (of 6,299 total)
  • in reply to: Webstation plug in (no record) #11007
    You should check that the key file PlgNotification_Reg.xml is located inside your project in the C:\SCADA\Projects\YOUR_PROJECT\Instances\Default\ScadaWeb\config folder
    in reply to: export event data to postgres #11006
    Please provide log file without download. Publish it on Google Drive or copy error here.
    I forgot to mention that I am testing rapidscada in a vmware virtual machine do you think that is a problem?
    VMware is OK.
    in reply to: ModAutoControl_Reg.xml not found. #11005
    Check that ModAutoControl_Reg.xml exists inside the project.
    Also check that the keys are not ignored on the project upload form.
    Keys files are transferred when a project is uploaded to server.
    in reply to: Rapid SCADA 6 Beta #10999
    For the next beta update we should at least add historical and event reports. Currently the work is in progress.
    in reply to: export event data to postgres #10998
    MdDbExport_xxx.log that connection to database cannot be established. Check connection settings. The full error message is not visible on the screenshot.
    in reply to: If and then implementation #10994
    Please find the project file for review as below
    Project review is out of the support.
    Please ask particular questions.
    Please provide a screenshot of Notification plugin that contains visible notifications.
    Still don’t see it.
    in reply to: Notification installation and start #10993
    Configuration of plugins is a part of Rapid SCADA project. XML files should be located in the project.
    If you changed plugin configuration file in the project, you should upload it to the server to run.
    in reply to: Webstation – Web Application Configuration #10992
    All that settings are inside your project. Restore the project from your backup and upload to server.
    Reinstallation is not needed.
    in reply to: Quantites and Units #10990
    The Quantities table contains physical quantities.
    The Units table contains units of measurement, and may contain enumeration values.
    For example, 10 meters.
    Quantity is length.
    Meter is unit.
    • This reply was modified 3 years, 8 months ago by Mikhail.
    in reply to: Profile and secret key #10989
    You can copy correct secret key from C:\SCADA\ScadaAgent\Config\ScadaAgentConfig.xml
    in reply to: Event types #10988
    Yes, you can add custom statuses. To use them, you need formulas that return corresponding statuses.
    The Units table does not contains channel statuses. It may contain enumerations.
    in reply to: My formula #10987
    Possible formula:
    Cnl; Cnl>0?4:CnlStat
    in reply to: My formula #10986
    According to the manual, a part of the formula that calculates channel status is followed by semicolon.
    in reply to: More ‘native’ scheme editor #10985
    Scheme Editor is a complex application, that is why is is not planned to make it an extension for the Administrator app as Table Editor.
    In the future, it is possible to choose a one of the following approaches for Scheme Editor:
    1. Make it a separate WinForms app that wraps web browser.
    2. Make it a web app.
    in reply to: export event data to postgres #10970
    Export DB module writes information to log files located in C:\SCADA\ScadaServer\Log
    Check log files for errors.
    Please publish screenshots as JPEG or PNG, not PDF.
