Webstation plug in (no record)
Forum Home Forums Understanding the Software Webstation plug in (no record)
  • #11003
    victorlam
    I have installed notification plug in with trial key.
    After registration with the provided key according to the computer code, there is no reminder on the registration. But after the laptop is reboot again, then there is registration reminder that the notification plug in cannot be triggered with changes of the register values.
    Please advise if this can be solved or not.
    #11007
    You should check that the key file PlgNotification_Reg.xml is located inside your project in the C:\SCADA\Projects\YOUR_PROJECT\Instances\Default\ScadaWeb\config folder
    #11344
    victorlam
    Thanks for the help. Now I will check this every time for this Reg_xml file.
    #11363
    Plugin registration simplified in v6.
