Viewing 15 posts - 2,326 through 2,340 (of 6,299 total)
  • in reply to: Notification plug in (trial key vs paid registration key) #11215
    there is no acknowledgement sound alert when the status of the defined registered is changed
    Press F12 to check browser error messages in the console.
    in reply to: Notification plug in (trial key vs paid registration key) #11214
    Permanent and trial keys work similar. If some function does not work as expected, it is not caused by using trial key.
    in reply to: Menu order of Interface #11213
    The described issue is fixed in Rapid SCADA 6.
    In version 5, as a workaround you could locate a home scheme in the subfolder.
    in reply to: Server is unavailable Error #11212
    You can check application log files via the Administrator app.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11192
    That is really interesting. Thanks a lot!
    I will try to build Rapid SCADA using your description. I will write about my experience in this topic.
    If you decided to make a guide with screenshots as a Word, Libre Office or Google document, it may be useful to save information.
    in reply to: API to access server comm line device status #11191
    Could you provide more details how you’d like to see it?
    in reply to: Long loading times of schemes #11190
    I confirm that sometimes the described issue happens. Likely it is caused, when data request has no response from server. We will fix this issue when start redesign of schemes in the next generation of scheme engine.
    in reply to: Rapid SCADA 6 Beta #11189
    If a post contains a lot of hyperlink, it can be automatically blocked by the forum protection system. Sometimes, it’s more handy to provide a one link to Google document for example.
    I found and accepted your post.
    in reply to: Web API, REST API, version 6 #11188
    Now I can access SCADA API from Node-RED easily.
    Cool!
    in reply to: Rapid SCADA 6 Beta #11176
    @123abc56, deadband logic is updated and will be included in the next release.
    in reply to: API to access server comm line device status #11174
    Yes.
    Add an extra channel for a device, set its TagCode to Status and Format to Device status.
    in reply to: More ‘native’ scheme editor #11172
    A web app seems like the better option due to being cross-platform. However, implementation of property editor is tricky.
    • This reply was modified 3 years, 8 months ago by Mikhail.
    in reply to: communicator question #11171
    Will communicator send all device tags while we restar the server and communicator ?
    When Communicator starts it sends all tags for each device after a session with it.
    If Server restarts, it does not affect sending all data or changes only.
    Do we have any Interface to access the communicator state?
    In version 6 device status can be bound to channel.
    in reply to: Long loading times of schemes #11170
    that scheme is loading for really long time
    When loading takes a long time, is loading result successful?
    Try to open the same scheme on Windows Server and compare with other machines.
    Check the size of the scheme file.
    in reply to: export event data to postgres #11169
    ModDbExport_001.txt says that only events are exported, because the queues for current and archive data are not in use. You should check the module configuration.
