MikhailModeratorYou should not use ScadaComm and ScadaWeb for user log in. They are used for connection of applications.
You should create new users in the Users table.October 25, 2022 at 7:42 am in reply to: Digital Counter and calculate elapsed time for a channel in certain state #11404
MikhailModeratorI’ve updated the above formula. Please try it again.
MikhailModeratorHow about by using a slim custom bootstrap?
I replied in the comments of the pull request.
how if we set our scheme completely a graphic, text globally not selectable?
Please explain it more detailed.
MikhailModeratorI’m doing a content translation for Chinese Simplified, thank you
It it very useful. Please make a pull request when ready.
Just now I find that the MQTT related plugin UI are not working ScadaAdmin
The problem occurs on Windows also or only on Linux?
Please explain the question with the examples.
Sending emails successfully is described in this topic.
MikhailModeratorPlugin registration simplified in v6.
Could not open the link above. Please check.
In the device template, a user enters tags of device. Channels should be created by the channel wizard.
MikhailModeratorThe archiving interval, configurable target archive for channels are all long wished features.
These features required a lot of work. We try to listen our users. However, implementation can take a long time.
There is this Archive Kind table, not sure what to set in there.
If it’s empty, download the latest update and take this table from the Administrator’s template.
Could you provide screenshots? Probably, you need some update.
October 24, 2022 at 10:00 am in reply to: Where are those goodies (comm status, toggle comm line cmd) in v6 Channel setup #11358
MikhailModeratorDevice status can be bound to a channel.
Set the channel’s tag code to Status
It is possible to start and stop communication lines using commands from Server.
The following tag codes are supported:
App.Comm.StartLine
App.Comm.StopLine
App.Comm.RestartLine
App.Comm.StartAllLines
App.Comm.StopAllLines
App.Comm.PollDeviceCommand value may contain line number or device number if needed.
Tag codes are listed here.
It’s possible, but more tricky. Check the averaging formulas.October 24, 2022 at 9:54 am in reply to: Digital Counter and calculate elapsed time for a channel in certain state #11356
The only way to get the server to accept it is to delete certain conditions but it still doesn’t work,
The formula suggested above differs from the formula you posted. Try the original one. In case of errors, provide the error information.
