Forum Home › Forums › Understanding the Software › Dashboard plug in
- This topic has 9 replies, 2 voices, and was last updated 3 years, 8 months ago by
October 22, 2022 at 10:41 am #11347
victorlamParticipantHello,
Can any members share the Dashboard plug in? The procedures and setup steps etc. If possible, kindly help to share the results after the plug in result.
October 22, 2022 at 11:02 am #11348
victorlamParticipantI tried to copy this from DashboardExample1.xml to my program but not working.
<?xml version=”1.0″ encoding=”utf-8″ ?>
<DashboardConfig>
<DashboardOptions>
<Name>Dashboard Example 1</Name>
<ColumnCount>2</ColumnCount>
<AspectRatio>1.33</AspectRatio>
</DashboardOptions>
<Widgets>
<Widget type=”Chart” cnlNums=”101″ viewIDs=”2″ />
<Widget type=”Chart” cnlNums=”101″ viewIDs=”2″ mode=”fixed” period=”2″ title=”Sample Chart” config=”PlgChartPro.xml” />
<Widget type=”CurData” cnlNums=”101″ viewIDs=”2″ title=”Sample Data” />
<Widget type=”View” viewID=”2″ />
<Widget type=”CustomUrl” url=”https://www.youtube.com/embed/EEIk7gwjgIM” />
</Widgets>
</DashboardConfig>Kindly advise how can I proceed for this Dashboard plug in.
October 22, 2022 at 11:26 am #11349
victorlamParticipantNot sure how to fix this error???
https://drive.google.com/file/d/1oF2H9h9C50BAso_VzNGMf–fDMkrXRfB/view?usp=sharing
October 24, 2022 at 10:06 am #11362
Could not open the link above. Please check.October 24, 2022 at 10:11 am #11366
victorlamParticipantSOrry for the typo error here:-
October 25, 2022 at 7:44 am #11406
MikhailModeratorPage not found again.
October 26, 2022 at 12:55 am #11417
victorlamParticipantHope this should work..
October 26, 2022 at 1:00 am #11418
This one:-
https://drive.google.com/file/d/1oF2H9h9C50BAso_VzNGMf–fDMkrXRfB/viewOctober 26, 2022 at 1:06 am #11419
Still do not understand why the google is not working here.
This link should be fine.
October 26, 2022 at 10:57 am #11422
The plugin validates user rights by the view with ID = 2. You should create a table view or a scheme with ID = 2 that contains the channels to draw chart.Note: in version 6, access rights are assigned on objects, so configuration will be simplified.
