Currently, we login as admin and password =12345.
So may I know if can I use ScadaWeb with the assigned password and ScadaComm with the assigned password under WebStation? So that I can use these two login accounts and login via WebStation.
Or only admin and the default password can be succeeded for the login.
You should not use ScadaComm and ScadaWeb for user log in. They are used for connection of applications.
You should create new users in the Users table.
