*.aspx is an old ASP.NET extension. Webstation 6 uses Razor Pages for development.
MikhailModeratorDid you set passwords by clicking the Set Password button in the Users table in Administrator?
Did you also change passwords in Webstation and Communicator app settings?April 26, 2023 at 11:56 am in reply to: Understanding the data exchange between Rapid Scada and MySQL #12503
MikhailModeratorNavigate to a subforum, for example, this one. Scroll the page down to find a text field.
MikhailModeratorHi Matt,
1. SCADA\ScadaWeb\wwwroot\custom would be good.2. In the Views table set
Path = (any)
View Type = Web page view
Arguments = ../custom/mypage.html (may be it’s not correct, but we need to start from somewhere)
Title = (any)
There is no need to install an extra plugin for scripting. The above answer is correct.
MikhailModeratorAccording to System Requirements Windows Server 2016 is a minimum.
You could try to install Rapid SCADA 6 on Windows 10/11 for testing.April 26, 2023 at 11:38 am in reply to: Understanding the data exchange between Rapid Scada and MySQL #12497
MikhailModeratorDear Mr. Han,
Please create a new topic to discuss your question, because the current topic is about MySQL data exchange.
Webstation v6 uses .NET6. So an application pool, named “.NET v4.5” is invalid.
The Server service listens to the port 10000, not 80.
May be the module author @jurasskpark can help you.
Also make sure that *.View.dll has been copied to the ScadaAdmin\Lib folder.April 21, 2023 at 5:22 pm in reply to: Time difference between mysql DB and rapid scada server #12485
MikhailModeratorIn log files, the server’s time zone is used.
In the database, timestamps are passed in UTC. However, actual time zone is driver dependent.
In Webstation, time zone is specified by the web app configuration. By default server’s time zone is used. It can be changed in Administrator.April 21, 2023 at 5:08 pm in reply to: Understanding the data exchange between Rapid Scada and MySQL #12484
MikhailModeratorIf the module does not work as expected, check the module log file.
April 21, 2023 at 5:05 pm in reply to: Understanding the data exchange between Rapid Scada and MySQL #12483
If you need to write data to DB on button click, probably, you should try DB Import Driver (instead of DB Export Module). That driver can write data on command.
The driver library is DrvDbImport.dll
MikhailModeratorIf language file cannot be loaded, the error should be written in the log file.
MikhailModeratorWindows Server 2016 is OK.
Please check Webstation log file for errors.
Webstation 5.x is not compatible with Server 6.x and vice versa. -
