As far as i know there Is no script plugin. but you can link the Button to an output channel AND call a fórmula function from this channel. Fórmulas área writen un c# on the formulas table of the project database. Depending of your needs this behavior may be of help. If you la explain better your problem maybe i can give you a better tip
My problem is that I want to use a toggle button (Link 1) for starting exporting data from Rapid Scada to the MySQL DB (Link 2). The HMI which include this functionality should allow the supervisor to treat data provided to the database.
DB Export module exports data permanently. There is no feature to start and stop the export process.
DB Import driver allows to execute SQL by a command. It’s possible to use a button to execute a command.
