Forum Home › Forums › Installation Issues › Problem with WebStation
- This topic has 7 replies, 3 voices, and was last updated 2 years, 1 month ago by
April 25, 2023 at 2:59 pm #12488
rapidscada_sii
ParticipantHello,
I followed this https://rapidscada.net/doc/content/latest/en/installation-and-run/manual-installation.html to install Rapid SCADA and after managing my way to install everything, it seems that I still have a problem with my Webstation. All the dll are included and the configuration seems okay. The server runs on IIS on localhost/scada. So I try to access my login page, but it says “Please correct the following errors: The application is not ready. Try again later.”. So I checked my logs and here they are:2023-04-25 16:35:11 [FRIDF-L01064][.NET v4.5][ACT] Webstation 6.1.0.0 started 2023-04-25 16:35:11 [FRIDF-L01064][.NET v4.5][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\SCADA\ScadaWeb\ScadaWeb\ScadaWeb\bin\Release\net6.0\publish\FileStorage.dll 2023-04-25 16:35:12 [FRIDF-L01064][.NET v4.5][ACT] Plugin PlgChart 6.0.0.1 loaded from file C:\SCADA\ScadaWeb\ScadaWeb\ScadaWeb\bin\Release\net6.0\publish\PlgChart.dll 2023-04-25 16:35:12 [FRIDF-L01064][.NET v4.5][ACT] Plugin PlgMain 6.0.1.0 loaded from file C:\SCADA\ScadaWeb\ScadaWeb\ScadaWeb\bin\Release\net6.0\publish\PlgMain.dll 2023-04-25 16:35:12 [FRIDF-L01064][.NET v4.5][ACT] Plugin PlgScheme 6.0.0.0 loaded from file C:\SCADA\ScadaWeb\ScadaWeb\ScadaWeb\bin\Release\net6.0\publish\PlgScheme.dll 2023-04-25 16:35:12 [FRIDF-L01064][.NET v4.5][ACT] Plugin PlgSchBasicComp 6.0.0.1 loaded from file C:\SCADA\ScadaWeb\ScadaWeb\ScadaWeb\bin\Release\net6.0\publish\PlgSchBasicComp.dll 2023-04-25 16:35:12 [FRIDF-L01064][.NET v4.5][ACT] Plugin PlgWebPage 6.0.0.0 loaded from file C:\SCADA\ScadaWeb\ScadaWeb\ScadaWeb\bin\Release\net6.0\publish\PlgWebPage.dll 2023-04-25 16:35:12 [FRIDF-L01064][.NET v4.5][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins 2023-04-25 16:35:12 [FRIDF-L01064][.NET v4.5][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin 2023-04-25 16:35:12 [FRIDF-L01064][.NET v4.5][ACT] Receive the configuration database 2023-04-25 16:35:12 [FRIDF-L01064][.NET v4.5][ERR] Error checking server connection: Incorrect format of data received from the server: data length is too big
The lasts 2 lines are repeating as long as the server is running. I guess it could be a problem somewhere in my ScadaWebConfig.xml. So I checked and I have those lines for ConnectionOptions:
<ConnectionOptions>
<Name>Default Connection</Name>
<Host>localhost</Host>
<Port>80</Port>
<Username>****</Username>
</ConnectionOptions>I tried to change localhost to localhost/scada and to http://localhost/scada. But both of those tries gave me another error in the logs : “Unknown host”.
Do you have any idea of where to search or what to do to correct this error ?
April 25, 2023 at 4:30 pm #12491
Webstation v6 uses .NET6. So an application pool, named “.NET v4.5” is invalid.
The Server service listens to the port 10000, not 80.April 26, 2023 at 12:22 pm #12504rapidscada_sii
ParticipantThanks, it works, but I discovered I had issues with my services when I fixed this. After putting every missing file where it belong, it seems that I still have a problem.
Here are lines of the WebServer logs:
2023-04-26 14:14:10 [FRIDF-L01064][FRIDF-L01064$][ERR] Authentication failed for user ScadaWeb: Invalid username or password
2023-04-26 14:14:12 [FRIDF-L01064][FRIDF-L01064$][ERR] Authentication failed for user ScadaComm: Invalid username or password
So I downloaded the configuration to the Administrator app and it seems that the password configured are correct fot those two users according to their Configuration files. Do you have any ideas why it would fail there ? (I tried to change passwords in the Administrator and updload it in the Server but the operation failed)April 27, 2023 at 10:33 am #12509
MikhailModeratorDid you set passwords by clicking the Set Password button in the Users table in Administrator?
Did you also change passwords in Webstation and Communicator app settings?April 27, 2023 at 3:02 pm #12516rapidscada_sii
ParticipantI checked and everything seemed alright, also it stopped doing this error. Now I have this error log in the Webstation:
2023-04-27 15:47:00 [FRIDF-L01064][.NET v6][ERR] Error loading configuration: Padding is invalid and cannot be removed. 2023-04-27 15:47:00 [FRIDF-L01064][.NET v6][ACT] Receive the configuration database 2023-04-27 15:47:02 [FRIDF-L01064][.NET v6][ERR] Error checking server connection: Server and client secret keys do not match.This error in ScadaComm:
2023-04-27 16:14:19 [FRIDF-L01064][FRIDF-L01064$][ERR] Error loading configuration: Padding is invalid and cannot be removed. 2023-04-27 16:14:19 [FRIDF-L01064][FRIDF-L01064$][ERR] Normal execution is impossibleAnd this error in ScadaServer:
2023-04-27 16:14:22 [FRIDF-L01064][FRIDF-L01064$][ERR] Archive Cur not found in the configuration database 2023-04-27 16:14:22 [FRIDF-L01064][FRIDF-L01064$][ERR] Archive Min not found in the configuration database 2023-04-27 16:14:22 [FRIDF-L01064][FRIDF-L01064$][ERR] Archive Hour not found in the configuration database 2023-04-27 16:14:22 [FRIDF-L01064][FRIDF-L01064$][ERR] Archive Events not found in the configuration database 2023-04-27 16:14:22 [FRIDF-L01064][FRIDF-L01064$][ACT] Start listener on port 10000 2023-04-27 16:14:22 [FRIDF-L01064][FRIDF-L01064$][INF] Archive in DAT format: C:\SCADA\ScadaServer\ScadaServer\ScadaServerWkr\bin\Release\Archive 2023-04-27 16:14:22 [FRIDF-L01064][FRIDF-L01064$][INF] Archive copy in DAT format: C:\SCADA\ScadaServer\ScadaServer\ScadaServerWkr\bin\Release\ArchiveCopy 2023-04-27 16:14:22 [FRIDF-L01064][FRIDF-L01064$][ERR] Unable to read current dataAnd the secret keys are the same in every config files.
This reply was modified 3 years, 4 months ago by
rapidscada_sii.
April 28, 2023 at 7:04 pm #12520
MikhailModeratorProbably, secret keys have invalid format. Generate new secret keys by opening Server – General Options – Listener Options – Generate button
July 6, 2024 at 1:08 pm #14902lijincheng
Participant2024-07-06 20:50:38 [DESKTOP-C8OHCM1][DESKTOP-C8OHCM1$][ACT] Receive the configuration database
2024-07-06 20:50:45 [DESKTOP-C8OHCM1][DESKTOP-C8OHCM1$][ERR] Error checking server connection:
Incorrect format of data received from the server: incorrect transaction ID
My mistake is like this, how should it be fixedJuly 8, 2024 at 9:22 am #14908
MikhailModeratorWhat lines in ScadaServer.log after the Server service starts?
