MikhailModeratorAfter build, the executable and other files should be correctly copied to the runtime location as the installer does. Services must be registered in the system. Then they can be started.
Could you provide a screenshot?
My be it’s better to create new components inheriting them from the existing, because in this case you have more freedom to add new features.
The instruction is here. In Rapid SCADA 6 the Formulas table was renamed to Scripts. You should copy from line 21 to 205.
The formulas also should work on the 6th version.
MikhailModeratorI think, it’s better to develop new components using the existing components as base classes, or as examples.
There is no password in ScadaAdmin. However, it would be useful.
You could prevent other users to change the project it by configuring Windows access rights on the application and project folders.
ScadaClient is class is not thread safe, while you executeclient.GetCurrentDatain many threads.
Old versions are not published. I suggest to upgrade to the latest version.
If you need to move the software to another server without any changes, copy files and use this instruction.
MikhailModeratorMake sure that you don’t ignore registration keys when upload the configuration. The checkbox must not be set.
https://ibb.co/RT4kMz6
Please provide more info related to the question.
Open the file C:\SCADA613\ScadaAgent\Config\ScadaAgentConfig.xml and check the Directory parameter. In your case, it should be C:\SCADA613\
After change ScadaAgentConfig.xml, restart the ScadaAgent6 service.
I want these to work well with all of Rapid SCADA’s components and possibly other components plugins .
It would be nice.
Could you advise on whether I should integrate these directly or if there’s an existing model I should follow?
Internal editor mechanism should be significantly updated to support such feature. The question is quite abstract.
MikhailModerator
Scheme Editor is a Windows application that interacts with a web page. Administrator permissions are required to open TCP port, so web page can get and send data to the application.
MikhailModeratorIs it possible to simply link Rapid Scada 6 to Influx DB Cloud?
Yes, it’s possible. Take into account that a free Influx DB cloud tier is very limited.
