If the channel 101 changes not too often, you can measure it’s value every minute. If it’s 1, increase the channel 102. Does this method fit your needs?
August 21, 2024 at 11:25 am in reply to: Modbus TCP No sending command for write new value to slave device #15193
MikhailModeratorAlso check the communication line log after sending a command to get a error message.
Please provide a screenshot of the Modbus template.August 21, 2024 at 11:23 am in reply to: version about ScadaSchemeEditor not match between source code and setup #15192
MikhailModeratorThat’s true.
New Scheme Editor for version 6 is under development.
Check the version history.
MikhailModeratorMany developers in China are unable to access YouTube due to network restrictions. To help them, I kindly request permission to upload the RapidSCADA 6.0 video tutorials to Bilibili, a popular video platform in China.
I assure you that all copyrights will be respected. The original content will remain unaltered, and full credit will be given to RapidSCADA, including links back to the original videos.
Yes, you can upload the videos providing the original links.
Is there an option to download videos from Youtube automatically and upload to another hosting?
MikhailModeratorBackward compatibility is provided for data archives.
You need to update all files, not only binaries.
MikhailModeratorit asks me in addition to the IP address and port of the server, the address of the device (from 1 to 247) and the number of the register.
Default TCP port is 502 for Modbus. Address is 0 in your settings. But I suggest to change it to 1. Register addresses are shown in the Modbus template on your screenshot.
Thank you for your positive feedback.
I strongly recommend to upgrade to Rapid SCADA 6. We significantly improved Modbus Slave driver to make it easier to configure. Is it possible for you to upgrade and then discuss the up to date version?-
This reply was modified 1 year, 10 months ago by
Server 5 and Server 6 must use different TCP ports to be able to work in parallel. Client applications should connect to a proper TCP port.
does updating from 6.1 to 6.3 require data imigration ?
Projects are compatible. Project migration is not needed.
How to pack souce rapidscada code project to installation .exe file setup ?
Build the source code according to the instructions. Then copy the files from your build output to the necessary folders.
MikhailModerator
MikhailModeratorLikely, it should be connected to the Linux server where the Communicator service is working.
According to the logs, Rapid SCADA 6 works well. But you open Rapid SCADA 5.
Try http://localhost:10008 (by default)
MikhailModeratorYou can set Modbus ID in the device options (Communicator app). Unit ID = 1 is the most popular. Could you provide screenshots of your settings?
August 19, 2024 at 8:14 am in reply to: Modbus TCP No sending command for write new value to slave device #15159
Could you clarify your question by providing screenshots?August 19, 2024 at 8:05 am in reply to: RapidGate from Rapid SCADA 6.3.0 to Rapid SCADA 6.2.1? #15157 -
