Viewing 15 posts - 841 through 855 (of 6,289 total)
  • in reply to: Logic of archiveMask #15392
    So, does this mean that the Archives table can cover up to 32 entries at most?
    31, because the archive mask is signed integer.
    in reply to: Logic of archiveMask #15391
    When writing, it’s possible to write to multiple archives simultaneously, so using a mask is appropriate.
    However, when reading, you can only read from a single archive, so a bit is used.
    Correct.
    Also check the ArchiveMask class.
    in reply to: Precision Loss Due 64-bit data #15390
    I’ve checked the source code of the driver. It converts numbers to Double.
    Do you have any ideas on how to get around this?
    in reply to: I have issue about database import (MYSQL) #15388
    Don’t forget to specify tags for a query. One tag per line.
    It’s in the device properties.
    • This reply was modified 1 year, 9 months ago by Mikhail.
    in reply to: Error at Exporting Data Manually with ModDBExport #15387
    Yes.
    in reply to: OPC DA no values received #15386
    It looks like Node Red does not send any data to the OPC client. If Node Red supports OPC UA instead of OPC DA, use OPC UA.
    You can try setting “Read synchronously” checkbox for the subscription.
    in reply to: I want to display text from decimal numbers. #15368
    Channel values are converted to strings automatically when displayed. If you face displaying issues, please provide screenshots.
    in reply to: Precision Loss Due 64-bit data #15367
    How do you transfer data between CodeSys and RapidSCADA?
    By default, channel values uses Double type. If you change a channel to use Int64 type, it can help. However, it may depends on a transfer method.
    in reply to: Communicator error “unable to read data packet header” #15366
    That’s good.
    I suggest TCP View utility to check all ports in use.
    in reply to: server is unaviliable #15365
    Check ScadaAgent.log to make sure that the Agent service is working.
    in reply to: Error at Exporting Data Manually with ModDBExport #15363
    The channels specified in Manual Export window should be created in the Output channels table. Those channels are used to send a command from the module to the Server app.
    in reply to: I have issue about database import (MYSQL) #15362
    Please make a screenshot of a device data page in Communicator.
    in reply to: Hourly countdown formula #15336
    The idea can be:
    1. If the input changes from low to high value, write a timestamp in a channel of the Calculated type.
    2. Add a channel to calculate the difference between now and stored value.
    3. If the input changes from high to low value, set the timestamp channel to undefined.
    I can answer certain questions about script syntax and available formulas. Creating complex scripts is programming, so it’s a paid service.
    in reply to: Windows Scada project upload in Ubutu #15334
    You can use the Hercules Utility to check connection from Windows to Linux. Use the Linux IP address and TCP port 10002.
    in reply to: server is unaviliable #15333
    First of all, check that the directories specified in the Server settings exist.
