server is unaviliable
Forum Home › Forums › Runtime Bugs › Server Bugs › server is unaviliable
Viewing 10 posts - 1 through 10 (of 10 total)
  • #15327
    non33691
    Sorry, I have edited the data in scada adminstrators and uploaded the config, but when I try to login, it says service is not available. and I already try to reset iis. Here is my scadasever.log
    2024-09-04 12:23:38 <NON><SYSTEM><ACT> ScadaServerService 5.1.4.2 is started
    2024-09-04 12:23:38 <NON><SYSTEM><ERR> The configuration database in DAT format directory does not exist.
    The interface directory does not exist.
    The archive in DAT format directory does not exist.
    The archive copy in DAT format directory does not exist.
    2024-09-04 12:23:38 <NON><SYSTEM><ERR> Normal program execution is impossible
    2024-09-04 12:34:04 <NON><SYSTEM><ACT> ScadaServerService is stopped
    Thank you 🙂
    #15333
    First of all, check that the directories specified in the Server settings exist.
    #15341
    non33691
    screenshot
    Here is my Server directories. I think it’s right.
    #15342
    non33691
    screenshot link : https://ibb.co/rc7m0r1
    #15343
    Look here
    • This reply was modified 2 years, 1 month ago by manjey73.
    #15347
    Once you have installed it on the disk, then you need to fix it there
    #15348
    non33691
    thanks, I already fix my directory path and then I upload config and got new problem. https://ibb.co/dkqW98d
    #15349
    Make sure that your port 10002 is not occupied by another program. Well, check that the port is open (although it seems to be open on the local computer)
    #15350
    I only have one question, why are you using version 5? it is no longer developing.
    #15365
    Check ScadaAgent.log to make sure that the Agent service is working.
