Logic of archiveMask
Forum Home Forums Development and Integration Logic of archiveMask
  • #15376
    showmustgoon
    I need to customize an event that supports both real-time and historical queries. If I add a new type in the Archives table in sequence and ensure that the archiveMask covers that bit when calling WriteEvent, will that work? I’m not entirely sure if this is the best implementation.
    I’m uncertain about the calculation rules of archiveMask. Is it calculated based on the sequential order of entries in the Archives table? So, does this mean that the Archives table can cover up to 32 entries at most? Is my understanding correct?
    #15378
    Yes, the number of bits is limited for archives and events. But you can create the necessary ones yourself from the code, only the code should do checks when creating, since the code that you assume may be occupied by another or has already been created.
    #15382
    showmustgoon
    And…..archiveBit?
    I just noticed that when writing an Event, archiveMask is used, but when getting Event, archiveBit is used. This should be the reason why I can’t read the events I wrote. I am now tracking the logic of archiveBit.
    #15383
    showmustgoon
    I think I finally figured it out.
    When writing, it’s possible to write to multiple archives simultaneously, so using a mask is appropriate.
    However, when reading, you can only read from a single archive, so a bit is used.
    Additionally, I made another mistake: I used the maximum and minimum values of DateTime as parameters for TimeRange, which caused an overflow.
    My test code is as follows, and the archiveMask and archiveBit used for writing and reading correspond to each other.
    if (DateTime.Now-LastTime>=TimeSpan.FromSeconds(10))
                LastTime=DateTime.Now;
                ServerContext.WriteEvent(16,new Event
                    Timestamp = DateTime.UtcNow,
                    CnlNum = 1,
                     DeviceNum = 1,
                    CnlVal = 11,
                     CnlStat = CnlStatusID.Defined,
                    Text = "123321",
                    Data = new byte[]
                    {0x00,0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09 },
                    // Position = 0
               var r= ServerContext.GetEvents(4, new TimeRange(DateTime.Today.AddDays(-2),DateTime.Today.AddDays(2), true), null);
               Log.WriteMessage($"Custom Events{r.Count},{string.Join(",",r.Select(x=>x.Timestamp))}",LogMessageType.Info);
    • This reply was modified 1 year, 11 months ago by showmustgoon.
    #15391
    Correct.
    Also check the ArchiveMask class.
    #15392
    31, because the archive mask is signed integer.
