PostgreSQL should be configured to allow password authentication. Check this link, for example.
MikhailModeratorThe
Timestampvariable is not available in v5. UseDateTime.UtcNowinstead.-
This reply was modified 1 year, 7 months ago by
MikhailModerator1. Find and stop the application that uses port 10000.
2. Install Rapid SCADA.
3. Change TCP port used by Rapid SCADA.
4. Start the app that uses port 10000.OR
1. Change the port of that app that uses port 10000.
Please check the error details in ScadaWeb.log
MikhailModeratorCool!
November 4, 2024 at 7:44 am in reply to: Hello World Tutorial – “The requested view is not specified” #15568
MikhailModeratorOK
MikhailModeratorRapid SCADA supports MQTT out of the box.
MikhailModeratorPublished at https://rapidscada.net/store/Module/en/ExtScriptCompilerJP
Kepware should support Bacnet. However, you should look for less expensive alternative.
MikhailModeratorHow the new software module will be related with Rapid SCADA?
More info is needed to answer your question.
In this case you can write data to the archive on change. A timer will not provide such accuracy.October 22, 2024 at 11:17 am in reply to: Rapid SCADA 6.3.1 Installation, TCP port 10002 already in use. #15543
You can change the TCP port of the ScadaAgent service after installation.
Before starting installation, switch off KT Kernel & System.
I suppose, writing a script on your favorite language. -
