Viewing 15 posts - 631 through 645 (of 6,288 total)
  • in reply to: Events not changing #16151
    Probably the issue is caused by the archive mask. Try setting the archive mask to empty.
    in reply to: Events not changing #16149
    Let’s consider one channel that should generate event’s, but it does not.
    Please make a screenshot of that channel properties, the Events page.
    in reply to: Is there a text field control? #16148
    I will create a custom page with text fields, transferring data. Should work, shouldn’t it?
    That’s technically possible if you are OK with JavaScript.
    in reply to: Support for Version 5.8.x #16147
    Version 5 is not recommended for new installations. Use version 6.
    Technical support, i.e. answering questions, is available and continues.
    in reply to: Events not changing #16140
    Please provide screenshots of the settings.
    in reply to: Is there a text field control? #16139
    You should add buttons on a scheme. When an operator clicks the button, a command dialog containing a text field is displayed. Set the Output channel property of the added buttons, and set proper button actions.
    in reply to: can not send command by web #16137
    Please provide screenshots of your settings.
    in reply to: No Table Editor #16136
    In v6, Table Editor is included in the Administrator app as a default extension. When you double-click a table view, it should be opened in the editor.
    in reply to: Out of Range Channel Data Mask #16125
    Conversion should be made using channel formulas as written above.
    in reply to: I would like to inquire about the visible/invisible function. #16120
    Connecting cameras also discussed here.
    in reply to: I would like to inquire about the visible/invisible function. #16119
    1. If you are asking about schemes, we plan to implement that feature in the future.
    2. To display a video stream you need to convert it to a web format. See this example.
    in reply to: Using AD for login #16112
    Have you created a PostgreSQL database and specified it in ScadaInstanceConfig.xml?
    in reply to: Using AD for login #16109
    Download is not needed in 99% of cases.
    When you upload a project, it is saved. You can also save the project by the Save button.
    If you gen an error, check the error details in the log files.
    in reply to: Change output state by formula #16108
    I thought all configurations should be done for channel which is referred in formula but configuration should be done on channel which execute formula, I’m right?
    Both is possible. A channel should not call SetVal for itself. When you need to change a channel itself, return a new value from the formula.
    in reply to: Using AD for login #16104
    1. In the Server – Modules page, activate the ModActiveDirectory module.
    2. Configure the module properties.
    LdapTest utility may help to find proper parameters.
