I would like to inquire about the visible/invisible function.
Forum Home Forums Understanding the Software I would like to inquire about the visible/invisible function.
  • #16113
    kangmin
    hello.
    I have two questions.
    1. Studying RAPID SCADA SYSTEM CIMON SCADA has a visible/invisible function. I am curious if it exists in RAPID SCADA.
    2. I am also curious about whether it is possible to check through real-time streaming of IP CAMERA.
    I’m sorry for my poor English and information retrieval skills.
    #16114
    Explain what visibility/invisibility means to understand?
    And what exactly did you mean by checking the camera?
    You can show it in screenshots, for example, for understanding, if possible.
    • This reply was modified 1 year, 4 months ago by manjey73.
    #16116
    There is no support for IP cameras, you need an intermediate link in the form of a gateway from camera streams to the WEB.
    You can display your own web windows in scada.
    If that’s what you’re talking about.
    #16117
    kangmin
    Thank you for your reply.
    I understood that CCTV real-time streaming is not possible.
    What is the meaning of visible/invisible in question 1?
    I was talking about a case where the image appears when a specific bit is 1 and disappears when it is 0.
    As I tried to write as concisely as possible, I think the content became difficult.
    sorry.
    #16118
    There are no built-in drivers for working with cameras (RTSP, ONVIF, etc.), but you can output your html page on the mnemonic to the Frame (see the top-up components of the diagrams). And use third-party repeaters of the stream from video cameras on the WEB.
    I can give you a link to one Russian product that allows this, but I haven’t tried it myself yet.
    #16119
    1. If you are asking about schemes, we plan to implement that feature in the future.
    2. To display a video stream you need to convert it to a web format. See this example.
    #16120
    Connecting cameras also discussed here.
