Using AD for login
Forum Home › Forums › Uncategorized Issues › Using AD for login
  • #16102
    LPG57
    Please advice which steps to be taken in 6.4 in order to use AD for login.
    #16104
    1. In the Server – Modules page, activate the ModActiveDirectory module.
    2. Configure the module properties.
    LdapTest utility may help to find proper parameters.
    #16105
    LPG57
    I activated the ModActiveDirectory module, filled in IP of the DC and “mydomain.local” in the search root. I the saved and downloaded. But when open modules again, the ModActiveDirectory module was back in the unused modules pane. I have tried several times with the same result.
    #16106
    LPG57
    Found that it worked when doing an upload instead. Can you please describe when to use upload and when to use download?
    But now when trying to login, I get: “Please correct the following errors: Error updating user information in database”
    #16109
    Download is not needed in 99% of cases.
    When you upload a project, it is saved. You can also save the project by the Save button.
    If you gen an error, check the error details in the log files.
    #16111
    LPG57
    I get the following error when I try to login with a domain account:
    2025-02-01 16:06:07 [SERVER8][SERVER8$][ERR] Module ModActiveDirectory: Error updating user information in database:
    Failed to connect to 127.0.0.1:5432
    2025-02-01 16:06:07 [SERVER8][SERVER8$][ERR] Checking username and password for user myusername is not successful: Error updating user information in database
    2025-02-01 16:06:11 [SERVER8][SERVER8$][ERR] Module ModActiveDirectory: Error updating user information in database:
    2025-02-01 16:06:11 [SERVER8][SERVER8$][ERR] Checking username and password for user myusername is not successful: Error updating user information in database
    Is there a need for security groups in AD like in older versions of RapiScada?
    #16112
    Have you created a PostgreSQL database and specified it in ScadaInstanceConfig.xml?
    #16167
    LPG57
    Is there a manual how to “create a PostgreSQL database and specified it in ScadaInstanceConfig.xml”
    #16171
    I suppose, PostgresSQL provides a manual to do that. PostgreSQL is not a part of Rapid SCADA.
    ScadaInstanceConfig.xml already contains settings to connect to the local PostgreSQL database, named rapid_scada, using postgres/postgres for username and password. Use the existing settings for testing.
