Out of Range Channel Data Mask
Forum Home › Forums › Communicating with Devices › Modbus › Out of Range Channel Data Mask
  • #16121
    cooldjmc
    Is it possible for Rapid SCADA to handle out-of-range channel data read from a device? For example, if a channel reads 0xFFFFFFFF (4294967295), could it display “–” or another designated character instead of the numerical value?
    The desired behavior is to display a mask, such as “++++” or “—-“, whenever a received value falls outside the expected range for that channel.
    Thank you
    #16122
    Send a channel to the double.NaN and you will see ---
    #16123
    cooldjmc
    Hi, please can you be more specific, where I must set the double.NaN in comunicator or a channel formula?
    #16124
    In the input formula of the channel, you can check for an input value greater than 100 example
    Cnl > 100 ? double.NaN : Cnl
    Or write a more complex formula and add it to the Script tables and call it in the input formula.
    Scripts & Formulas Documentation
    #16125
    Conversion should be made using channel formulas as written above.
