Events not changing
Forum Home › Forums › Understanding the Software › Events not changing
Viewing 10 posts - 1 through 10 (of 10 total)
  • #16132
    LukasD
    with my PLC, it seems the events are not fired based on the state of the inputs. I have 8 digital inputs defined as “Inputs” and have set the event mask on all, but when the input status changes, it does not trigger an event. Is there something I’m doing wrong?
    Thanks!
    #16140
    Please provide screenshots of the settings.
    #16142
    LukasD
    Which settings exactly? Channels?
    #16143
    LukasD
    This is what’s going on:
    And these are the channel settings:
    #16144
    LukasD
    Let’s consider one channel that should generate event’s, but it does not.
    Please make a screenshot of that channel properties, the Events page.
    #16150
    LukasD
    Hey,
    so…take a look. This is the channel no. 1, which I mention in the screen recording.
    https://ibb.co/1fXjpZsJ
    #16151
    Probably the issue is caused by the archive mask. Try setting the archive mask to empty.
    #16152
    LukasD
    yeah, that did the trick. But what is the reation? Would like to avoid it in future.
    Thanks!
    #16157
    Event archive should be selected. An empty value means all default archives.
