Find and check the SCADA\ScadaServer\Log\CalcEngine.cs file. This file is used by the Server service basing on the Scripts table. You can see that a preprocessor directive brakes the C# syntax. Use constants instead of directives.
MikhailModeratorData files may be corrupted due to hard drive issues or sudden power outage.
Please check the ScadaWeb.log file for the error details.
MikhailModeratorUse the DatViewer utility to check the event files. Event files are SCADA\Archive\Events\events*.dat
May be an event file is corrupted.
MikhailModeratorCan someone provide an example of what the deployment profile entries should look like?
Please create a new forum topic to discuss this question.
I thought entering the same thing on another computer in our network would display the same page, but it just times out.
Allow incoming connections to the port 10008 in the Windows firewall settings.
> what is the function of Pull to period
For example, you set it to 10 seconds. If a timestamp of the point is 10:59:51, it will be changed to 11:00:00.> what is the function of Use in-memory cache
Caching will be useful when data from multiple devices arrive at the same time stamp. This usually happens when a new hour begins. In this case, the channel values for this time stamp, which are necessary for calculations using formulas, will be read from the DB only once. If the project has many thousands of channels with formulas, the difference in data processing speed will be significant.A driver should support reading archives from your devices.
MikhailModeratorLet’s discuss another topic in the appropriate forum thread. Use the search, maybe the answer is already there.
MikhailModerator“An error occurred while processing your request.” is a sub message.
If you see it, check the details in ScadaWeb.log
When it happens?
There is no plans to adopt SchemeEditor for Wine, because I hope, the new MimicEditor will be released. But I don’t know when it happens. The work in progress.
Can you run ScadaAdmin on arm64? If so, how to achieve that?
Please provide screenshots of the module settings and log.
What are the versions of the Server service and the module?
MikhailModeratorRapid SCADA 6.4.1 has been released.
– Improved API of plugins and extensions (backward compatibility is supported)
– Fixed errors in MQTT and DB Import drivers
– The Server service writes initial command values to events before calculating by formula
– PostgreSQL historical archive supports in-memory cachingThe projects are fully compatible with the previous release.
MikhailModeratorYou can see that the Channel column is empty. It should be filled by the channel numbers. I suggest to delete the channels related to the device (in the Channels table) and create channels again using the wizard.
This reply was modified 1 year, 2 months ago by
MikhailModeratorAfter you successfully displayed a table view, you should check a data page in Communicator to make sure that you receive valid data from devices.
MikhailModeratorPlease check ScadaWeb.log for the error details.
MikhailModeratorWow! Windows is unpredictable sometimes.
