Scada webstation not getting open
Forum Home › Forums › Installation Issues › SCADA-Web Installation › Scada webstation not getting open
Viewing 15 posts - 1 through 15 (of 16 total)
  • #16316
    hellovijay78
    Dear sirs,
    I had istalled the Rapid SCADA in my windows 10 proffessional 64 bit. I had installed it with the help of video instruction in the site. All the area was successful as per the video but when I open webstation I am getting an error message.The error message is “HTTP Error 500.19 – Internal Server Error”. Will you please help me to install and use it? Please.
    #16320
    Please check the ScadaWeb.log file for the error details.
    #16338
    Sparkle75
    I have a full view on my localhost computer if I open the web page up either as localhost or using its IP address. I can also log in on a remote computer using the Webstation host computer’s IP address. However, I see no data on the remote computer, as shown in the attached picture. This is sooo close to working properly, but I just can’t determine what I am doing wrong.
    https://drive.google.com/file/d/1XqHNYqGkgXJOtcvXfnNa5XhyCqPQ-qTA/view?usp=drive_link
    https://drive.google.com/file/d/1iplEw68bVb6PpOYLhEcmr5enVg6S1ygy/view?usp=drive_link
    Webstation log shows it is operating with no errors.
    #16340
    The web browser in the 2nd picture looks very old. You should update the browser to the latest version.
    #16343
    Sparkle75
    That was the solution. The older machine close to my area is not capable enough. I tried it in another area of the plant with non-vintage computers and it works just fine! Thank you!
    #16344
    Mani_TheCat
    Hi Mikhail,
    I’m having the same issue after installation where I cannot open the workstation. I don’t know how to check the ScadaWeb.log file. Can you please help me with it?
    #16641
    Mani_TheCat
    This is what Im seeing :
    <configuration>
    <location path=”.” inheritInChildApplications=”false”>
    <system.webServer>
    <handlers>
    <add name=”aspNetCore” path=”*” verb=”*” modules=”AspNetCoreModuleV2″ resourceType=”Unspecified” />
    </handlers>
    <aspNetCore processPath=”dotnet” arguments=”.\ScadaWeb.dll” stdoutLogEnabled=”false” stdoutLogFile=”.\logs\stdout” hostingModel=”inprocess” />
    </system.webServer>
    </location>
    </configuration>
    <!–ProjectGuid: b4495bf2-c904-4bfe-bf3b-fe38cf0fc378–>
    #16653
    What do you see in the modules window?
    Note that ASP.NET 8 must be installed after IIS.
    #16656
    Mani_TheCat
    Yah the ASPNetCoreModuleV2 was not showing before in my IIS. And I had to look and download and that fixed the issue.
    By any chance can you link me with some example projects backup? I will try to restore the project and learn from there.
    My main idea is to just display values in a table format directly read from Modbus device and store it in a database for historical retrieval and viewing.
    If you can provide me a project that closely resembles to my scope that will be awesome
    Thanks,
    #16667
    The Hello World project is in C:\Program Files\SCADA\ProjectSamples\HelloWorld
    Other projects are owned by the customers.
    There is a YouTube video about connecting devices by Modbus. It should not be hard.
    #17537
    fischerp
    I have the same problem as described above and don’t understand the proposed solutions. The version is 6.2.2.
    To describe the problem precisely: When I try to open the web interface with “localhost:10008,” I get the following error:
    HTTP-Fehler 500.19 – Internal Server Error
    Auf die angeforderte Seite kann nicht zugegriffen werden, da die zugehörigen Konfigurationsdaten für die Seite ungültig sind.
    (that means: The requested page cannot be accessed because the configuration data for the page is invalid.)
    Rapid scada is installed by the setup.exe. Rapid Scada was installed with ScadaSetup. Various dependencies were missing, which were flagged during installation and were installed or activated by me. The installation process was then completed without errors. I then opened the sample project. The log files shown in the installation video display the same content for me as in the video.
    Is there a setting missing here?
    Do I need to start another service?
    ScadaAgent
    ScadaComm
    ScadaServer
    have been started
    #17540
    The issue is somewhere in IIS configuration.
    Could you make a screenshot of your IIS management console?
    Especially the modules section. Example
    #17568
    Gabor
    Hello! I had issue installing Rapid Scada (came with error) on Windows7 and make the Webstation to work, when I realized one of the comment said Win7 is no longer supporter (however rapidscada.net stated win7 is supported with SP1, but now I see its for the old documentation) So a bit confusing,as I am new to Scada.
    Also noticed Rapid Scada is no longer Free?
    I mean if we want to make working projects with tags (sensor input reading,plc,visualization,etc) it is not free anymore.. Just wanted to confirm.
    Thank you
    #17569
    The scada core itself is free and open source. There have always been paid components that you can do without, except in some cases.
    someone installed dancing and tambourine on Winows 7. but in general, yes, it’s better to use Windows 10 or 11.
