use C# preprocessor error
Forum Home › Forums › Understanding the Software › use C# preprocessor error
  • #16317
    詹森
    https://github.com/njzsky/Public/blob/main/PrepeocessorErr.png?raw=true
    I can use C# preprocessor directives normally, but they throw an error when used in Rapid SCADA. How can I solve this problem?
    As shown in the figure, thank you for your answer!
    #16322
    Find and check the SCADA\ScadaServer\Log\CalcEngine.cs file. This file is used by the Server service basing on the Scripts table. You can see that a preprocessor directive brakes the C# syntax. Use constants instead of directives.
